Results 1 to 9 of 9
Thread: curved footpath
    Full Member watso75's Avatar
    AutoCAD 2007
    Jan 2008
    32
    Default curved footpath
    ok, heres my problem. I am drawing up on outdoor amphitheatre. The amphitheatre is fine but i need to draw a curved footpath on a gradient. I am using 2007 Autocad and am struggling with which tool is best to use. Thought of using loft but need to get the gradient as smooth as possible. Any suggestions
    Full Member Alex_AW's Avatar
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    The Koran says 'You should go by the straight path'. So you should use lines for the footpath.
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    For the agnostics amongst us, the Koran is a book of fiction containing lots of ridiculously made-up stories in a similar way to that of the Bible
    Life's constantly changing - keep up or get left behind
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    There's an AutoCAD Bible serial of books, but no AutoCAD Koran or AutoCAD Talmud any. That's unfairly.
  5. #5
    Super Member
    AutoCAD not applicable
    Jul 2007
    639
    Religion & CAD , just a little off topic
    Watso....I'm sure some of the modelling guru's here would approach this differently, but I'm still stuck at first principles
    If the grade was constant, just draw a flat slab, rotate to required grade,
    Then create cutting solids for subtraction....
    If this isn't clear..give us a screen shot of what your working on & I'll try and help out.
    If at first you don't succeed, then maybe failure is more your style.
  6. #6
    Super Member chrisdarmanin's Avatar
    chrisdarmanin's Computer Details
    win 10
    HVAC
    chrisdarmanin's Discipline Details
    Building Services Draughtsman
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    maybe sweep??
  7. #7
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    291
    What about OFFSET3D?
    Draw a centerline for the footpath as a 3D-Polyline and offset this one to both sides. Using RULESURF you can get a horizontal ruled surface to describe the way.
    Regards
    Jochen
  8. #8
    AutoCAD 2007
    Jan 2008
    32
    cheers for the tips guys. I got there in the end. I drew my contoured footpath and the drew a horizontal line the specified width of the fooptah at one end and used sweep.
  9. #9
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,730
    Quote Originally Posted by scj View Post
    Regards
    Jochen
    Rulesurf is an obsolete command for someone using AutoCAD 2007.
  1. Curved sides
    By marinebro0306 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Aug 2006, 09:10 am
  2. curved wall
    By lukas in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Dec 2005, 02:59 pm
  3. curved text
    By willsy in forum AutoCAD General
    Last Post: 4th Nov 2005, 01:53 pm
  4. curved edges
    By goldie in forum AutoCAD Drawing Management & Output
    Last Post: 1st Sep 2005, 11:39 am
  5. Curved text
    By curteanu in forum AutoCAD Beginners' Area
    Last Post: 17th Aug 2003, 12:35 pm
