Results 1 to 3 of 3
    Full Member
    AutoCAD 2012
    Sep 2007
    55
    Default Making Osnap snappier
    Okay, is there a way to increase the "strength" of the "magnet" effect, with regards to object snap (I use both AutoCAD '07, and '04 at work)? I am finding the performance a little sluggish compared to what I am used to, sort of like trying to draft through marshmallows, and I am convinced that the cause of my frustration is that the object snap doesn't lock on soon enough, or strong enough, hence, I feel as if I have to slow down a little every time I approach an endpoint, or center, or whatever. I realize that the workstation may be at fault, I use an iMac (Parallels) at home, but I've noticed the same thing with the PC's at work. I have manipulated just about every user preference I know of, could the speed of the computer (hard drive speed, amount of RAM) make a big difference, or is there some advanced settings that are not in the normal menus?
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    You can turn the magnet on/ off- I'd look at that first;
    OPTIONS- Drafting Tab
    Also you can change the Aperture of the snap box(?) in the same tab- I would suggest you play around with some of the settings there to start...
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
    Full Member
    AutoCAD 2012
    Sep 2007
    55
    Thanks for the suggestions....I did some more experimentation and I discovered that the difference in performance had a lot to do with my computer after all (note to all aspiring Macintosh CAD users- when running AutoCAD on Parallels, with Windows and MacOS running alongside each other, applications used by Windows are emulated to some degree, particularly the video/graphics performance, but when you boot up in Windows alone, the performance is (should be) 100%) but thanks anyway.
  1. osnap
    By rookie37 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2007, 03:13 pm
  2. Osnap to the end of a leader
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2005, 02:40 pm
  3. Error with OSNAP
    By khairulfikri in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jun 2005, 05:53 pm
  4. osnap
    By mechdraw1 in forum AutoCAD Beginners' Area
    Last Post: 8th Aug 2004, 09:45 pm
  5. OSNAP
    By Dan in forum AutoCAD Beginners' Area
    Last Post: 22nd May 2003, 08:42 am
