How did you create it? If you use Draw>Modeling>Sphere it should be a 3D Solid.
I just learnt that a sphere is not a solid. How can I convert it into one (or create one from scratch)? I need it to create a rounded hole (using the subtract command).
Or REVOLVE a closed profile half circle.
Select the one you have made hit Ctrl+1 to see it's poperties.
Nick
http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
http://s240.photobucket.com/albums/ff241/dyNick_Scots/
http://designgraphicsshowcase.blogspot.com/
High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
Home - AMD 2.1GHZ - 512Ram, 64 Video,
Laptop Inventor 7, Autocad 2004, Corel 11
Actually, you're right. I made it into an ellipsoid using an autolisp program called scaleaxis (scale along a chosen axis only), and appearantly it doesn't preserve the solidity of the object. I just thought it was the sphere that wasn't a solid to begin with.
Okay, in that case, I need to know how to create an ellipsoid. Would I just create an ellipse and revolve it around its major axis?
Draw a solid sphere and convert it to block. Change the scale factor along the desired axis-it should be an ellipsoid.
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
revolve half an ellipse...
