Hi,
you set it in the copy-command:(red is input)
Command: COPY
Select objects: 1 found
Select objects:
Current settings: Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>: o
Enter a copy mode option [Single/Multiple] <Multiple>: s
Specify base point or [Displacement/mOde/Multiple] <Displacement>:
This returned the Copy mode to Single....
/Petri
, but it (setting it right at the command line) doesn't work for say, 2004 (I am forced to use '04 at work). The command line prompts are different in '04, they don't give you the option of choosing the "mOde", only setting "Multiple" for each event, but it always reverts to "Single" for the next instance of the command. Anybody know how to switch the settings for version 2004, so that I can have "Multiple" Copy as the default?
