Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    nicolas's Computer Details
    Windows 7
    Intel Dual Core 64 Bits
    2 GB
    AutoCAD 2015
    Jan 2008
    Rose Hill, Republic of Mauritius
    420
    Default lines wrt to angle of elevation of other lines
    Hi Everybody,
    I have a tremendous problem in drawing inclined lines wrt to other lines. One example is straight line AB drawn 135 deg to the horizontal and 1000 units long. I want to draw another straight line AC, that is from point endpoint A, again 1000 units long. I want to draw it in such a way that the line is 90 deg from line AB.
    I know I can do it simply by 135 deg - 90 deg equalling 45 deg and drawing the line 1000 unit 45 deg from the horizontal. However I want to know how do we draw line set at relative angle from other object angle of inclination, without doing the maths???
    Next thing is where can I get a free block of a man or woman (in causual clothes) standing to put it before a front elevation?
    Thank you in advance, a prompt and detailed answer will be much welcomed.
    Nicolas.
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    I can help you with the first question.
    You need to get hold of a lisp routine called MCR.LSP. That way you can copy rotate an object to suit what you want. I'll post it here. if you have problems with it, just yell, many members here will fill you in with how it works:
    MCR.LSP
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Hi,
    Thank you very much for the swift answer. However I am far from grasping how this will work and help me. Its just beyonf my ability. You see I understand that ACAD angle works counterclockwide and I can draw any line of any dimension in 1:1 at any angle for example a line at 45 degree 100 unit long, I type 100 < 45 to get 45 with the horizontal east. My problem is the "with the horizontal east", I don't want 45 degree from the horizontal east rather from another angle.
    I will check tonight if I can work out the routine, how to install and use it and I will let you know tomorrow if I was able to do something good about it.
    Thank you very much for the good work.
    Nicolas.
    Map 3D 2009
    Jun 2006
    4,181
    Hey, Nic. Tutor time.
    Acad can measure angles both clockwise and counterclockwise. Just depends on how you set it up in the first place. The default is called Architectural standards, which starts from East at 0 degrees, and measures counterclockwise. For civil/survey we change that to north being 0 degrees, and measuring clockwise.
    But that does not matter for you at the moment.
    Just draw another line over the one you want to rotate. Then type the command ROTATE and pick that line, doesn't matter which one gets picked. When you are asked for a base point, pick the base point you want the rotation to occur about.
    Then when asked to enter the rotation angle, just type 45. If it rotates to the wrong side, just start again. This time enter -45. If you are happy with that, go back and delete the first rotation line. It really is that simple.
    If you are still unsure, please get back to us. If it worked, and you understand now, still get back to us. We love to know that our assistance has been a help.
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    In this particular case, where you want a 90° angle, one way would be to offset the line AB by 1000. Then C is in the correct position, then grab the other end of the line, and dock it onto A.
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Draw line AB, for line AC at the command line prompt, LINE Specify first point: Select the PERPINDICULAR OSNAP, then select the line you want to be PERPINDICULAR to, then select Point A, then type in 1000.
  7. #7
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Default Thank
    HI Everybody,
    I do believe that the information will indeed help me. I will read all of the post and do all the required homeworks and practicing and I will be back to you upon success.
    Nicolas.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    What about this
    LINE
    Specify next point or [Undo]: @50<45<45
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    If one returns to the title of the thread of how to draw lines wrt other lines, then perhaps a simple solution would be to draw a line, then copy that line onto itself, and then rotate the copied line to the required angle from the first line
  10. #10
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Default Preliminary Results
    Hi Everybody,
    I have tried the first explanation by Cullen and it works. I used the copy command to recopy the line AB (1000 unit, 135 from horizontal) unto itself. Then I used the ROTATE command on one of the line (original or copy, I don't know), select A as base point and and rotate by -90 degree and it was 90 deg from line AB which is what I wanted. line AC which is 1000 unit and 90 deg from AB.
    The second explanation from Eldon does work. I offset AB (still 1000 units, 135 from horizontal) and docked the farthest northern endpoint onto A. However, I don't understand the logic behind this method? How about other ANGLES from A?
    SLW210's explanation seemed good and I was able to reproduce it at home. I used LINE command, Shift-Right Click Perpendicular osnap, click the line AB, and hover the picbox on A, type 1000 and there is a line 1000, 90 deg or perp from AB. However, I wish to know if there is a similar system for the other angles and also I did not see any DEFERRED OSNAP. How to get it?
    As for Bigal? Unable to do it, surely due to some setting problem. What is the principle behind: @50<45<45. This is the first time I see double "<".
    Nicolas.
  1. LInes
    By primoz in forum AutoCAD Beginners' Area
    Last Post: 16th Apr 2007, 11:00 pm
  2. double lines from single lines?
    By asperated in forum AutoCAD General
    Last Post: 4th Jan 2007, 03:36 pm
  3. set lines to UCS
    By Jeffnm in forum AutoCAD General
    Last Post: 31st Jul 2006, 03:10 pm
  4. dotted lines plotting as solid lines
    By Dave^ in forum AutoCAD Beginners' Area
    Last Post: 11th Jan 2006, 01:16 pm
  5. Between the Lines
    By CADTutor in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2004, 07:32 am
