Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Default Object Snap Problem
    I have recently loaded acad 2008 and am finding that the intersect snap does not work on some lines, does anyone know why?
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Are they on the same z axis? If not you could use apparent intersection?
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Yes, apparent int. does work but checking the lines on properties they are all on Z0.
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Are the lines solid or dashed?
  5. #5
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    All solid. Is it possible they are minutely off Z 0, and is there a way to move everything to Z 0?
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Attach the file.
  7. #7
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    File too large to attach. Have found that although properties says lines are on Z 0.000000, if i make start and end points Z 0, the intersect osnap works! How can I move everything to Z 0 universally?
  8. #8
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    PROPERTIES- change the Z value.
  9. #9
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    This one has come up a lot in the last couple of weeks. Is there a problem with Z values creeeping in? Are survey strings being brought into drawings that aren't sorted properly? Even 0.0000001 will cause problems. For those who have Express, flatten every thing. For those who don't, I have no answer.
  10. #10
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Quote Originally Posted by Alan Cullen View Post
    ...For those who have Express, flatten every thing. For those who don't, I have no answer.
    To embelish a little on my previous answer, you can select everything, then bring up the PROPERTIES box, then input the z value a zero.
  1. Deferred Perpendicular Object Snap - how do I use it ?
    By RWeber in forum AutoCAD Drawing Management & Output
    Last Post: 24th Sep 2008, 10:53 pm
  2. Using object snap with different z-values
    By Siberian in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Mar 2008, 11:59 pm
  3. Object Snap
    By sagaa in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Aug 2006, 03:25 pm
  4. Object snap lock problem
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2006, 05:33 pm
  5. object snap disappeared...???
    By hughesey in forum AutoCAD General
    Last Post: 4th Oct 2005, 10:32 pm
