Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member Laurel's Avatar
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Default Construction Problem
    Hi
    I've a problem with regards to the attached drawing. If anyone can help, I'd be very grateful.
    The drawing represents a screen for a motor-boat. You can see an Isometric view, side elevation and plan (all white layer, 0). Each window in the screen is hinged, so that the window can be folded flat into the horizontal plane. (Shown as the yellow layer, FOLDED OUT). A2 represents A1 folded out, and B2 represents B1.
    I'm struggling to draw an accurate representation of C1. How do I do it, please?
    Thanks,
    Paul.
    Paul
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You should have a book that covers developments.
    Personally I would do it as 3D as there is miter concerns that don't show up in an infinately thin flat.
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Thanks for the suggestion JD.
    I must admit, I'm not sure how you arrived at the drawing you have labelled C1, but I don't think it is correct.
    Looking at your drawing, you have labelled the corners of my plan view of C1 as 1 to 4. I would expect the side you have labelled 2 to 3 to be the same length as the left most edge of the plan view labelled B2, but in your drawing of C1, it isn't.
    Or am I missing something?
    Paul
    Full Member Alex_AW's Avatar
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    Something like this.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I had Point 3 in the wrong location.
    ...be the same length as the left most edge of the plan...
    I've never been able to follow a description like this - I have to refer to point labels to understand what we're talking about.
  6. #6
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    Quote Originally Posted by Alex_AW View Post
    I'm not absolutely sure about that variant.
    This one (see attached file) looks more correct from theoretical point of view, but length of 3-4 line on the involute does not equal one on the top view.
    I think you'll have to make a 3D model or cut one from paper to be sure in a variant. If more sensible advises wouldn't come, of course.
  7. #7
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Thanks everyone for your sueggestions.
    Alex - I can see where you are coming from with your first suggestion, but it looks a little too skewed to me. I'm not sure about how you have arrived at the 2nd option
    JD - I don't know 3D (yet). You suggested a book on developments. Can you suggest one?
    I've wracked my brain, trying to remember how I learnt how to do it years ago, and arrived at the drawing I have attached. I'm not sure of how accurate it is, but it looks right. Any comments?
    Thanks again,
    Paul.
    Paul
  8. #8
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    Quote Originally Posted by Laurel View Post
    ... I'm not sure about how you have arrived at the 2nd option
    The key is here.
  9. #9
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    ... it looks right. Any comments?
    About the results. Lines don't coincide a bit with each other.
    About the way you've got it I'd say nothing . I didn't analyze it - I'm afraid for my brain .
  10. #10
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Yes, I see you are right - my solution doesn't fit either.
    I'm struggling to resolve this, anybody else know how?
    Paul
  1. Geometric Construction Problem
    By Laurel in forum AutoCAD General
    Last Post: 6th Aug 2007, 08:23 am
  2. Help Needed on Construction Line
    By vicale345 in forum AutoCAD General
    Last Post: 16th Dec 2006, 07:01 pm
  3. CONSTRUCTION LINE
    By steel_dragon in forum AutoCAD Beginners' Area
    Last Post: 25th Jul 2006, 12:29 am
  4. Dome Construction
    By ABJ in forum AutoCAD Drawing Management & Output
    Last Post: 8th Mar 2006, 02:09 pm
  5. Construction Line + Perpendicular Snaps = problem
    By Volred in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2005, 11:44 pm
