Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    292
    Perhaps this could be a solution:
    I've drawn 2 3D-Polylines in the top-view (so they should have correct lengthes). Than I moved the upper onre to the correct heigth (taken from the side-view). As all partial faces of the screen seem to be even you can rotate them down to the plane z=0.
    Regards
    Jochen
  2. #12
    Senior Member Laurel's Avatar
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Thanks for the help, SCJ. I've not yet mastered the art of 3D autocad, and so have not attempted the drawing in 3D myself, and can't say if I agree with your solution.
    I've found the solution myself though, and have illustrated it in the attached drawing. I found an article in an old drawing book, which covered how to obtain the true shape of inclined triangles given an elevation and plan.
    Yay for me!!
    Paul
  3. #13
    Full Member Alex_AW's Avatar
    AutoCAD 2006
    Dec 2007
    Saint-Petersburg
    39
    Anyway your last solution looks the most correct beyond the rest 2D solutions. But there's something about it. You have started with point C, but if you were starting with point D you'd get a little different result. BTW - you can obtain it not such difficult way (look at the attached file).
    PS. After all of this I think that learning 3D modeling not such a bad idea .
  4. #14
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    I see what you mean. I really can't see where the 3mm discrepancy comes from. Everything else looks ok, and as I said, the solution was taken from a book. I thought the problem might lie with my original elevation and plan, but that looks ok too.
    Your quick solution looks to work well in this instance. It is possible to do in this case as we know the lengths of sides (ie AC and BD are in the vertical plane).
    There is another solution to our problem in the book I used, that is applicable for triangles that do NOT sit on the horizontal plane. I'll try that later to see if I can remove the discrepancy. For now tho, a 3mm tolerance in this case is perfectly acceptable, so I suppose I'd better get my drawing finished.
    I'll post the other solution when I get the chance, (and would love to know if anyone can trace the discrepancy between triangles ABC and ABD) but for now, thanks for your help!!
    Paul
  1. Geometric Construction Problem
    By Laurel in forum AutoCAD General
    Last Post: 6th Aug 2007, 08:23 am
  2. Help Needed on Construction Line
    By vicale345 in forum AutoCAD General
    Last Post: 16th Dec 2006, 07:01 pm
  3. CONSTRUCTION LINE
    By steel_dragon in forum AutoCAD Beginners' Area
    Last Post: 25th Jul 2006, 12:29 am
  4. Dome Construction
    By ABJ in forum AutoCAD Drawing Management & Output
    Last Post: 8th Mar 2006, 02:09 pm
  5. Construction Line + Perpendicular Snaps = problem
    By Volred in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2005, 11:44 pm
