Results 1 to 4 of 4
    Super Member
    AutoCAD 2008
    Jul 2007
    535
    Default Pipe Fitting Library
    On the Autodesk website it says they have libraries of ANSI, DIN, ISO and JIS pipe fittings.
    We use BS EN fittings. I'm wondering if you can get those too? Basically if we can get the sizes of fittings we need then we can get the software.
    Anyone able to shed some light on this? thanks
    Using AutoCAD2012, Civil 3D 2012, 3DS Max 2012, AutoCAD MEP 2011, Imagemodeler 2009, Zbrush, Solidworks, PTGui, Photomatix, Photoshop
    PORTFOLIO: http://www.flickr.com/photos/47676682@N04/
    Senior Member
    Architecture 2011
    Jan 2008
    100
    You would need to find a third party library - and probably pay for it too. I did a quick google search but didn't find anything so you may need to adapt another standard with the BS values.
    Pipework & Structural Steel http://www.3DCADMax.com
    Super Member
    AutoCAD 2008
    Jul 2007
    535
    Yeah i had a bit of trouble finding good information, but an engineer at work has pointed out that our pipe manufacturer Saint Gobain's pipes comply with BS, EN & ISO standards so they must be the same.
    Full Member basiony's Avatar
    basiony's Computer Details
    win7 Ult.
    Laptop-Dell-Insp 1565
    AutoCAD 2011
    Jul 2010
    39
    but where Can I lead the application in autocad 2011 for fitting the pipe ???
  1. curve fitting
    By iain9876 in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2007, 06:43 pm
  2. Changing a cold water pipe into a hot water pipe
    By Siberian in forum Autodesk Software General
    Last Post: 31st Jul 2006, 11:34 am
  3. Irregular Pattern Fitting
    By Nicko12 in forum AutoCAD General
    Last Post: 15th Dec 2005, 09:20 am
  4. flattening out the end of a pipe
    By Raider in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2005, 11:29 am
  5. Shop Fitting Wall Planning Application
    By markgobell in forum AutoCAD Drawing Management & Output
    Last Post: 4th Dec 2003, 09:31 pm
