Tree,bush & vegetation symbols/blocks
GIB39
Hi
I require some very good tree, bush and vegitation symbols for autocad.
Does anyone know of a good website where I can download these from?
Thanks
Guest Alan Cullen
Paul, too good an oportunity here.
I can take a leak every and any day behind a "very good tree, bush and vegitation"
Seriously, if you have no luck, yell, and I wiil send you some that I use.
But not tonight, I have to parcel them up and zip them. And I'm not in the mood to think too much at the moment.
Thanks
The tree, bush and vegitation symbols I found were not exactly as we required. I would appreciate it if you could send me the symbols you use, that would be a great help.
Thanks
I don't use these much in structural work, but here is a couple.
note its actually a .zip file but I had to rename it to .dxf for uploading here, (100kb limit)
just rename it to .zip.:)
  • 3 years later...
Erm, how do I download these?
You can't. It appears that PS_Port has removed the file.
Follow the link that James posted. You will find loads of CAD blocks on that site.
