Results 1 to 3 of 3
Thread: Line help
    Forum Newbie
    AutoCAD LT 2008
    Jan 2008
    4
    Exclamation Line help
    Hi
    Is there a way to draw a line and the dimension will automaticaly appear instead of drawing a line and then going to the dimension tab is this possible to do.
    Full Member MrMaggs's Avatar
    Map 3D 2006
    Jan 2008
    Cardiff, S Wales
    81
    You can always, after drawing your line, select liner/angled dim then right click/enter and then it prompts you to select object
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Make sure your dims are set to associative first.
    You may find this interesting reading:
    http://www.cadtutor.net/faq/question...Paper+Space%3F
  1. Change a continuous line to a dotted line
    By Brian in forum AutoCAD General
    Last Post: 1st Apr 2014, 11:35 pm
  2. Replies: 10
    Last Post: 8th May 2007, 04:45 pm
  3. can you turn a single-line into a double-line?
    By asperated in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2007, 10:22 am
  4. Drawing a parallel line to unknown angled existing line
    By berol in forum AutoCAD Beginners' Area
    Last Post: 29th Aug 2006, 12:06 pm
  5. Double line for multiple extrude line?
    By hyposmurf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jun 2004, 12:49 pm
