Results 1 to 4 of 4
Thread: Dimensions
    Forum Newbie
    AutoCAD LT 2008
    Jan 2008
    4
    Unhappy Dimensions
    Hi
    Im using a annotation scale of 1/1 the thing is when i draw a line and i add the dimension it always comes up real small is there a way to make this bigger without exploding it and then using the scale command to alter it.
    Alan how do i do that.
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    First thought, make sure your DIMSCALE is set to 1 in model space. I assume that is where you are dimensioning in.
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    If you are drawing Dimensions and they are to be annotative then you need to make the Dimstyle to be annotative too. This should negate any need to change Dimscale manually at any point.
    Maybe this will help:
    http://www.cadtutor.net/forum/showpo...26&postcount=4
    Life's constantly changing - keep up or get left behind
    Senior Member Laurel's Avatar
    Inventor 2012
    Feb 2007
    Yorkshire, UK
    145
    Hello
    Try leaving dimensions until you create your paperspace layout, then set your dimension style to 'scale dimensions to layout' (on the 'fit' tab).
    The size of the dimension text will then relate to the paperspace, rather than modelspace, and a text size of 3 will plot as 3mm high.
    Hope this helps.
    Paul.
    Paul
  1. dimensions
    By widow's son in forum AutoCAD Beginners' Area
    Last Post: 9th Aug 2007, 04:10 am
  2. Lay Out tab & dimensions
    By allmostawake in forum AutoCAD Beginners' Area
    Last Post: 17th May 2007, 09:55 pm
  3. Dimensions
    By djgraham20354 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jun 2006, 10:15 am
  4. Dimensions again!
    By johnnybond in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2005, 08:59 am
  5. dimensions
    By pennylove in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2005, 09:30 pm
