Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2004
    Feb 2008
    Brittany - France
    8
    Default VBA, blocks and selectionset
    Hello all
    First post on this forum !
    [my life]
    My name is John, I'm working in a shipyard in Brittany. I used to work on CoCreate ME10 system during many years but since a couple of years we changed our DAO system for AutoCAD 2004. I'm a kind of beginner with this...
    With this changing I lost all my scripts I've written on ME10 system
    Now I'm trying to do new VBA scripts to replace all the custom tools I had.
    I'm doing this with VBA because I know this language pretty good : I use VBA with Excel or Access and I don't want to learn a new one as autolisp !
    [/ my life]
    My problem is :
    We will received ACAD files containing nested steel plate parts, ready to be cut with a numeric plasma cutting machine. This files are done by an automatic output from a CAO system (FORAN).
    But we want to get the parts on single DXF ou DWG files : one part is one DXF/DWG file (and not one file with many parts).
    One part is defined by two layers : one layer describing the boundary of the plate and a second layer describing the marking on the plate.
    The files we will received will contain many layers, two layers per plate part:
    Example :
    Part #01
    -> layer "01" = boundary of the plate #01
    _> layer "M_01" = marking on the plate #01
    Part #02
    -> layer "02" = boundary of the plate #02
    _> layer "M_02" = marking on the plate #02
    etc.
    What I want to do is :
    - select layer "01" (containing lines, polylines, arc)
    - select layer "M_01" (containing lines, polylines, arc)
    - create a block "Part_01"
    - copy these entities in the block "Part_01"
    - rename the layer "01" as layer "Boundary"
    - rename the layer "M_01" as layer "Marking"
    - save the block "Part_01" in a DXF format (or dwg format)
    and then do the same things with layer "02"
    an alternative way would to do like this :
    - rename the layer "01" as layer "Boundary" in the selectionset
    - rename the layer "M_01" as layer "Marking" in the selectionset
    - save the selectionset as a dxf or dwg file.
    but I don't know if it's possible to do this without a block creation.
    I know how to select the layer I want and I've got an idea how to "browse" all the file to select all the layers "01"/"M_01", "02"/"M_02" etc. The choice of the layers is not a problem for me : it's a classic VBA problem.
    But what I don't know is how I can copy the selected objets to put them in the block I created. And after how to save this block in a single dxf or dwg file.
    Here is my code :
    Code:
    Sub SaveLayers()
    Dim sset As AcadSelectionSet
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    Dim groupCode As Variant
    Dim dataCode As Variant
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    On Error GoTo gestErr
    'Create the selectionset "JeuSel1"
    Set sset = ThisDrawing.SelectionSets.Add("JeuSel")
    'Sélection of marking layer and then boundary layer
    gpCode(0) = 8 'layer
    groupCode = gpCode
    dataValue(0) = "M_01" 'layer name
    dataCode = dataValue
    sset.Select acSelectionSetAll, , , groupCode, dataCode
    groupCode = gpCode
    dataValue(0) = "01" 'layer name
    sset.Highlight (True)
    'Create block
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "Part_01")
    'Copy each object selected in the block
    For Each acadObj In sset
    '----->Here is my problem ! How to add the selected object in the block "Part_01" ?
    Next acadObj
    Exit Sub
    gestErr:
    If Err.Number = -2145320851 Then
        ThisDrawing.SelectionSets.Item("JeuSel").Delete
        Resume Next
    Else
        Debug.Print Err.Number
        Debug.Print Err.Description
        Exit Sub
    End If
    End Sub
    Someone can help me ?
    Thank you and sorry for my english ! I hope you will understand me !
    John
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    this will write it out:
    ThisDrawing.Wblock "Part_01.dwg", sset
    /Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
    Forum Newbie
    AutoCAD 2004
    Feb 2008
    Brittany - France
    8
    Hello,
    thank you for this reply but with this I store the block without changing the layer's names.
    But I keep this reply because I will need it on the next step : store my finished block on hard disk.
    John
    Full Member
    AutoCAD 2008
    Apr 2006
    Los Angeles
    65
    Code:
    groupCode = gpCode
    dataValue(0) = "01,M_01" 'layer name
    'Create block
    ReDim Obj(sset.count - 1) As AcadObject
    Dim i As Integer
    For i = 0 To sset.count - 1
    Set Obj(i) = sset(i)
    Next i
    ThisDrawing.CopyObjects Obj, blockObj
    Exit Sub
  5. #5
    Forum Newbie
    AutoCAD 2004
    Feb 2008
    Brittany - France
    8
    OK ! Super ! Thank you
    it seems to work perfectly ! I 'm going to adapt it in my script and I will post the entire finish code soon.
    John
  1. Exploding Blocks within Blocks
    By fawellp in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2008, 09:56 pm
  2. Title Blocks, blocks being the word
    By James in forum AutoCAD Beginners' Area
    Last Post: 2nd Nov 2007, 03:40 pm
  3. Title blocks can you make oles into blocks.
    By Daithi02 in forum AutoCAD General
    Last Post: 31st Jan 2006, 02:15 pm
  4. 3Ds blocks and Multiview blocks exploding in viz render
    By Catch-22 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2005, 06:33 pm
  5. Deleting blocks and renaming blocks
    By Laurence in forum AutoCAD Beginners' Area
    Last Post: 4th Dec 2002, 10:41 am
