Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2004
    Feb 2008
    Brittany - France
    8
    Default VBA : find the lowest point in a selectionset
    Hello again,
    In way to define the insertion point when creating a block with a selectionset (see my previous here) I try to find the lower left point of the box containing all the entities in my selectionset.
    I think I found something in ACAD VBA help, a function to do this but I can't find it again.
    Thank you
    John
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Look at the GetBoundingBox Method.
    Forum Newbie
    AutoCAD 2004
    Feb 2008
    Brittany - France
    8
    Yes, of course ! I knew something existed !
    Thanks,
    John
    PS: here is my function :
    Code:
    'Look for the lower left point of all the entities in a selectionset :
    Function pntInsert(sset As AcadSelectionSet) As Variant
    Dim acadobj As AcadObject
    Dim minExt As Variant
    Dim maxExt As Variant
    Dim test As Boolean
    Dim pbas As Variant
    test = False
    For Each acadobj In sset
        acadobj.GetBoundingBox minExt, maxExt
        If test = False Then
            pbas = minExt
            test = True
        End If
        If minExt(0) < pbas(0) Then pbas(0) = minExt(0) 'x mini
        If minExt(1) < pbas(1) Then pbas(1) = minExt(1) 'y mini
    Next acadobj
    pntInsert = pbas
    End Function
  1. MOVING THE BASE POINT/ INSERTION POINT
    By nwmjdp in forum AutoCAD Beginners' Area
    Last Post: 13th May 2012, 06:44 am
  2. VBA, blocks and selectionset
    By John the frog in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2008, 10:15 am
  3. point to point instead of matrix method??
    By avantgarde in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2007, 05:59 pm
  4. find the midpoint between two point features thru lisp
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2006, 01:47 pm
  5. where to find
    By kesten3 in forum AutoCAD Beginners' Area
    Last Post: 30th Jul 2006, 02:42 pm
