Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2008
    Feb 2008
    2
    Default Beginner needing just a little help.
    Hi,
    I am pretty good with computers, and drawing programs like Photoshop. I am jusssttt starting to teach myself autocad. I build high detail models of farm equipment as a side income. Right now, I am trying to make a dwg of a particular tire so I can have a prototype cnc'd out and then I can mold and reproduce it. I have my dwg pretty close to what I want with one exception. I don't know to how alter the shape of my lugs (treads) yet. Can someone help me with that. Also, I would like to add some raised text to the sidewalls. I can probably figure that out pretty easy, but if someone could point me in the right direction that would be great.
    Thanks,
    Jason
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Just what alterations do you want to make to the treads?
    What type of font did you have in mind for the raised lettering? I think it would have to be exploded then reassembled using the polyline edit command ("join" option) then extruded. Of course the text round have to be laid out in an arc as well.
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    ... but we have a thread somewhere giving instructions on how to lay text in an arc - in case you were wondering
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    LElkins
    As for the text. How about getting the text as lines, and then use the imprint command?
    See todays Tip of the Day
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Not sure what you want to do to the treads, but I think _SOLIDEDIT>Face>Move on the command line or from the drop down menu, Modify>Solid Editing>Move Faces or Move Faces on the Solid Editing toolbar. There is also Taper Faces, Delete faces, Extrude Faces etc.
    Plenty of info on Creating 3D text and Arc Aligned text, just do a search.
  6. #6
    Forum Newbie
    AutoCAD 2008
    Feb 2008
    2
    Thanks for all the replies and help folks. I really appreciate it. Again, I've only been teaching myself this for about a week, so being pointed in the right direction is a huge help. I've messed around using your suggestions for about 5 minutes, and I think I'll be able to figure it out once I have a little more time. Below is a picture of how I would like my tread pattern to look. Thanks again
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Could you mock out the actual shape of the lugs and extrude them into the tire then union everything? Can you can a template or a tracing of the shape?
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by modelman View Post
    I've only been teaching myself this for about a week,... I've messed around using your suggestions for about 5 minutes, and I think I'll be able to figure it out once I have a little more time. Below is a picture of how I would like my tread pattern to look.
    Can you attach the file here.
    I would use Revolve (surface)
    Slice (with surface)
    Extrude
    Imprint (or other if you want raised lettering)
    Have you done the tutorials in my signature?
  1. beginner in 3d
    By chrisdarmanin in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jan 2008, 03:01 pm
  2. Needing help setting units..
    By CmC in forum AutoCAD General
    Last Post: 14th Jan 2007, 04:40 pm
  3. CSS for the beginner ?
    By David de Botton in forum Web Design
    Last Post: 6th Nov 2006, 10:21 am
  4. beginner
    By manyos in forum AutoCAD Beginners' Area
    Last Post: 18th Feb 2006, 08:16 pm
