Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Default Can i taper a linetype?
    Hi, im using AutoCAD 2007 LT, and i need to know if anybody knows of a way to taper a batting linetype to depict cut-to-falls insulation?
    Cheers Guys
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    Not to my knowledge... it's a complex linetype (unlike hidden or dashed) & doesn't change with polyline width the way other linetypes would.
    Only the lonely only ... PhotoGallery / Music
    LElkins
    As hedgehog has said, I am not aware of any tidy way to do this.
    You could use ACAD bodge-job tools such as WIPEOUT to provide the display you require.
    Cheers
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    It's very easy actually. Just set up linetypes and have associated linetype symbols defined in the linetype .shx file. If you want me to show you, just ask.
  5. #5
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by Alan Cullen View Post
    Hi Alan, thanks very much for your reply. if you could point me in the right direction of how to do this it would be very much appreciated!
    Cheers
  6. #6
    Map 3D 2009
    Jun 2006
    4,181
    First up, is this the sort of thing you are after?
  7. #7
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Attachment 4450
    No, sorry... what i need to do is in section, using the batting linetype to show insulation cut-to-falls starting from 75mm up to 150mm
  8. #8
    Map 3D 2009
    Jun 2006
    4,181
    Post an example.
  9. #9
    LElkins
    I assume you want something along the lines of this?
  10. #10
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Post an example.
    Ok, i have attached a pdf for you... hopefully this will make it all clear!
    Cheers
  1. Extrude with taper angle in VBA
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Sep 2009, 11:03 am
  2. Face taper of a cube?
    By CADIDAC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Dec 2007, 02:53 pm
  3. Taper window blocks
    By Kukaz in forum AutoCAD Beginners' Area
    Last Post: 19th Dec 2006, 06:22 pm
  4. Extruding a closed polyline with a taper, along a path.
    By BryanSchlegel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jan 2006, 04:47 pm
  5. cannot get taper to work on one of two solids
    By jsragman in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2005, 06:13 pm
