Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by LElkins View Post
    I assume you want something along the lines of this?
    Hi LElkins, if you look at the pdf on my last post it will show you what i need to do. I have already shown basically what you have, but i actually want to try to taper the linetype so it will fit the space without using 'bits' of lines.
    Cheers
  2. #12
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    ... and you're using an LT version so you can't use Lisps?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  3. #13
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by Strix View Post
    Unfortunately, yes i am using LT!! Its all good and well until you want to do something useful...
  4. #14
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    If you have a few standard width sizes for the walls, it can be done with linetypes for those wall widths.
  5. #15
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    Like this?
    Only the lonely only ... PhotoGallery / Music
  6. #16
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by Hedgehog View Post
    Like this?
    Hey thats looking like it! I would like to get it so that the batting 'loops' are in a consistant width rather than being squashed up at the low end, but if thats not possible then this will do totally fine...
  7. #17
    XP sp 3
    MEP 2009
    Aug 2007
    896
    The way I did it is completely impractical for your use (I think a few people here might be able to suss it ) sorry... just making sure that's the way you wanted it to look... I still reckon you're gonna struggle with this problem.
  8. #18
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    I'm thinking 3D and a perspective view?
    I think the solution to your thing Coey is to make it by hand...pull on the headphones, dig in and get it looking good with arcs and lines....
    MTJIGSTRING = BAZINGA
  9. #19
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    ... then save it somewhere as a block for next time, and use the scale functions when you insert, explode and hack off the bit you don't need
  10. #20
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Yeah i think you might be right there guys! i have been trawling endlessly through the internet for solutions to this but its been absolutely no use.
    I would have thought AutoDesk would have this one sorted tho, cut to falls is quite a common way of detailing insulation after all!
    Maybe its just my AutoCAD skinny version LT being the problem.
    Thanks anyway.
  1. Extrude with taper angle in VBA
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Sep 2009, 11:03 am
  2. Face taper of a cube?
    By CADIDAC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Dec 2007, 02:53 pm
  3. Taper window blocks
    By Kukaz in forum AutoCAD Beginners' Area
    Last Post: 19th Dec 2006, 06:22 pm
  4. Extruding a closed polyline with a taper, along a path.
    By BryanSchlegel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jan 2006, 04:47 pm
  5. cannot get taper to work on one of two solids
    By jsragman in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2005, 06:13 pm
