Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    I think it comes down to AutoCAD-geeks (as we all are, right? ) being so pedantic! Trust me Coey - noone will notice if that piece of insulation is slightly off...it's too bad, but it's like that..
    My moment of revelation came when I was out on site and I saw my drawings, that I had spent hours and hours getting right - being first shrunk from A1 to A3 (half for you imperical dudes) and then measured on with a yard stick..
    MTJIGSTRING = BAZINGA
  2. #22
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    how about blocking one 'curl', arraying it, then slapping successive scales on it, then blocking the result?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  3. #23
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    This was done slowly and manually, by extracting the "Bat" shape, and using Rotate 3D about the x-axis - not very practical, but I've got a quiet day
  4. #24
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by eldon View Post
    Thats exactly what i have been trying to do but i dont think the functions you suggest exist on Acad LT.
    I think i'll just go with what Tiger suggests, and just realise that no-one is really going to notice/care whether or not the linetype fills the space, im just trying to be too much of a perfectionist!
    Thanks a lot guys, its been helpful!
  5. #25
    LElkins
    OK. This isn't perfect by any stretch of the imagination, but it is an option for you.
    The attached drawing contains a dynamic block, which in turn contains 5 lines. It scales down to half of the start.
    There are 6 pick points, so you can stretch each portion of the insulation as you need it.
    Like i said, not perfect, but maybe you can play with it a bit.
    Cheers
  6. #26
    Junior Member
    AutoCAD LT 2007
    Dec 2007
    15
    Quote Originally Posted by LElkins View Post
    Cheers
    Yeah, this gives me the same result as chopping the lines and giving each segment a different linetype scale, thats the way i've decided to deal with the issue.
    It seems AutoCAD LT isnt intelligent enough to do what i want. Thanks for your help.
  7. #27
    LElkins
    Have just added a 'wish' to the AUGI wish list.
    The ability to set a start and end linetype scale, similar to the ability to set a start and end width with a pline.
    Cheers
  1. Extrude with taper angle in VBA
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Sep 2009, 11:03 am
  2. Face taper of a cube?
    By CADIDAC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Dec 2007, 02:53 pm
  3. Taper window blocks
    By Kukaz in forum AutoCAD Beginners' Area
    Last Post: 19th Dec 2006, 06:22 pm
  4. Extruding a closed polyline with a taper, along a path.
    By BryanSchlegel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jan 2006, 04:47 pm
  5. cannot get taper to work on one of two solids
    By jsragman in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2005, 06:13 pm
