Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,075
    Quote Originally Posted by bobsy852 View Post
    Brilliant! Thanks for that Styk!
    Just out of curiosity, how do you set that up as a script? just copy it into notepad and save it as a .scr?
    Yup, but each line break is just like you hit Enter on the command line. If you follow that rule then you'll make the *.SCR file just fine.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  2. #12
    Forum Newbie
    AutoCAD 2009
    Apr 2011
    8
    Default lines are crooked
    My horizontal and vertival lines are not square: they look crooked on the screen. I tried to flatten but it didn't help. What am I missing?
  3. #13
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,075
    Did you try the link I provided on the first page of this thread? Give that approach a shot and see if it works for you.
  4. #14
    Forum Newbie
    AutoCAD 2009
    Apr 2011
    8
    I don't think I did it correctly
  5. #15
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,075
    I'm going to need a little more info than "I don't think I did it correctly" if you need help.
    Can you explain why you don't think you did it correctly? What happened?
  6. #16
    Forum Newbie
    AutoCAD 2009
    Apr 2011
    8
    Default its gone!
    Well - I've never tried a lisp before, but I looked online to figure it out. I first tried to cut and paste - of course that didn't work. Then I tried to do every line individually and I moved it out of the drawing...somehow. It is gone!
  1. non coplanar
    By rookie37 in forum AutoCAD General
    Last Post: 25th Jan 2008, 05:07 pm
  2. Non Coplanar Issues
    By jjdavisarch in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2007, 08:49 pm
  3. Minimum distance between non-coplanar lines crossing over each other
    By asalameh in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2007, 12:52 am
  4. coplanar & non coplanar
    By gortex in forum AutoCAD Drawing Management & Output
    Last Post: 19th Apr 2006, 10:41 pm
  5. Make all lines coplanar
    By ktaylor in forum AutoCAD General
    Last Post: 20th Jul 2005, 11:42 pm
