Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2007
    Feb 2008
    1
    Default CAD X,Y co-ords and OS grids
    Hi - could someone explain how Ordinate Survey grids relate to X,Y,Z co-ordiantes of model space. We have surveyed positions on a site in eastern europe and the same points on the .dwg site plan match the OS co-ords for that region. Is 0,0,0 in Acad model space relative to the so-called 0,0 of that OS grid?
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    No it is not.
    You will have to identify a couple of points from the survey that are on your OS grid. Then move/rotate the whole drawing to those correct OS survey points.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    3,000
    If you are not using Latitude and Longitude, you are probably using coordinates from the UTM (The Universal Transverse Mercator Projection). This has 60 individual zones around the world extending 6° in longitude between limiting parallels 80° South and 84° North.
    So there are sixty 0,0 coordinates. Each set of coordinates should also accompanied by its UTM zone number, otherwise it is not unique.
    The Ordnance Survey grid is a particular one set up for the Britain excluding Ireland. So the coordinates in Eastern Europe have nothing to do with Ordnance Survey.
    There is no special relationship between Ordnance Survey and AutoCAD, which has one 0,0 assigned to wherever the user chooses.
  1. Looking for help generating grids
    By gedster in forum AutoCAD General
    Last Post: 19th Mar 2007, 10:50 pm
  2. extracting Co-Ords from Blocks with Attributes
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jan 2007, 10:13 pm
  3. Coordinates and Grids
    By StevePaul in forum AutoCAD Drawing Management & Output
    Last Post: 18th Feb 2006, 01:21 am
