Results 1 to 3 of 3
    Full Member
    Civil 3D 2007
    May 2004
    Tampa, Florida, USA
    41
    Default (code) erasing layers and what not
    Code:
    ;;; several function for erasing and purging entities on a given layer
    (defun c:del-layer (/ ent l_name ss cntr amt ssent)
      ;;; erases all enities on selected layer then purges that layer
      (setvar 'clayer "0") ; set layer to 0
      (if
        ; make sure we get something
        (setq ent (car (entsel "\nSelect layer to remove: "))); test
          ; extract the layer name from the entity
          (setq l_name (cdr (assoc 8 (entget ent))))
          ; create a selection set of all entites on layer 'l_name'
          (setq ss (ssget "X" (list (cons 8 l_name)))
                ; set 'cntr' to number of items in selection set
                cntr (1- (sslength ss))
                amt (itoa cntr); make a string from an integer
          (if
            ; does the sel set have anything in it
            (> cntr 0); test
            (while
              ; as long as 'cntr' is greater than or equal to 0
              ; keep looping
              (>= cntr 0)
              ; extract the ename from the sel set
              (setq ssent (ssname ss cntr))
              (entdel ssent); delete that entity
              (setq cntr (1- cntr)); subtract 1 from cntr
      (command "_.purge" "LA" l_name "N")
      (princ (strcat "\nErased " amt " items"))
    (defun fx-rm-layer (l_name / ss sntr amt ssent)
      ;;; erase and purges all entites on 'l_name', a string
      ;;; returns the number of entites erased
      (if
        ; make sure the layer exists in the dwg
        (tblsearch "layer" l_name); test
        (progn ; continue
                amt cntr
          (if (> cntr 0)
            (while
              (>= cntr 0)
              (entdel ssent)
      (if (> amt 0)
      ; return the amount of entites erased
      amt
    (defun fx-make-layer-list (/ ent l_name entlst)
      ;;; generate a list of layer names based on user selection
      ;;; and returns that list
      (while
        ; while user is selecting something continue loop
        (setq ent (car (entsel "\nSelect Item on Layer: "))); test
        ; extract layer name from selected entity
        (prompt l_name); output the layer
        (if
          ; make sure the layer isn't already in the list
          (not (vl-position l_name entlst)); test
          ; if not then add it to the list
          (setq entlst (cons l_name entlst))
    (defun c:del-purge (/ lst)
      (setq cmd (getvar 'cmdecho))
      ; turn off the echo!
      (setvar 'cmdecho 0)
      (if
        ; make sure we get a list before we continue
        (setq lst (fx-make-layer-list)); test
        ; now that we have a list run 'fx-rm-layer' on each of those items
        (mapcar '(lambda (x) (fx-rm-layer x)) lst)
      ; reset the variable
      (setvar 'cmdecho cmd)
    My signature goes here
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Thanks Mark for the generous contribution. Extremely useful - I'll add that to out AutoLISP archive if you don't mind.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Full Member
    Civil 3D 2007
    May 2004
    Tampa, Florida, USA
    41
    Quote Originally Posted by CADTutor
    not at all.
