Delete Layer(s)
Many new users of AutoCAD are surprised that it is not possible to erase a layer and all the objects on it using a single command - in fact I've often asked myself the same thing. Surely there ought to be a delete layer command. Well, load this lisp routine and you've got it.
This routine contains two commands:
del-layer simply removes any layer and all the objects on it that the user selects.
mdel-layer will do the same for multiple layers. Keep picking to add layers to a list and mdel-layer will delete them all in one go.
Both these commands are great timesavers and were donated by Mark Thomas - thanks Mark.
Code:
;   Delete Layer(s)
;   Written by Mark Thomas
;   This file contains 2 functions:
;   del-layer will delete all objects on a selected layer and purge it
;   mdel-layer will delete all objects on selected layers and purge them
(defun c:del-layer (/ ent l_name ss cntr amt ssent)
;;; erases all objects on selected layer then purges that layer
  (setvar 'clayer "0") ; set layer to 0
  (if
    ; make sure we get something
    (setq ent (car (entsel "\nSelect layer to remove: "))); test
      ; extract the layer name from the entity
      (setq l_name (cdr (assoc 8 (entget ent))))
      ; create a selection set of all entites on layer 'l_name'
      (setq ss (ssget "X" (list (cons 8 l_name)))
            ; set 'cntr' to number of items in selection set
            cntr (1- (sslength ss))
            amt (itoa cntr); make a string from an integer
      (if
        ; does the sel set have anything in it
        (> cntr 0); test
        (while
          ; as long as 'cntr' is greater than or equal to 0
          ; keep looping
          (>= cntr 0)
          ; extract the ename from the sel set
          (setq ssent (ssname ss cntr))
          (entdel ssent); delete that entity
          (setq cntr (1- cntr)); subtract 1 from cntr
  (command "_.purge" "LA" l_name "N")
  (princ (strcat "\nErased " amt " items"))
;;; erases all objects on selected layers and purges them
(defun c:mdel-layer (/ lst)
  (setq cmd (getvar 'cmdecho))
  ; turn off the echo!
  (setvar 'cmdecho 0)
  (if
    ; make sure we get a list before we continue
    (setq lst (fx-make-layer-list)); test
    ; now that we have a list run 'fx-rm-layer' on each of those items
    (mapcar '(lambda (x) (fx-rm-layer x)) lst)
  ; reset the variable
  (setvar 'cmdecho cmd)
;;; functions ======================================================
(defun fx-rm-layer (l_name / ss sntr amt ssent)
;;; erase and purges all entites on 'l_name', a string
;;; returns the number of objects erased
  (if
    ; make sure the layer exists in the dwg
    (tblsearch "layer" l_name); test
    (progn ; continue
            amt cntr
      (if (> cntr 0)
        (while
          (>= cntr 0)
          (entdel ssent)
  (if (> amt 0)
  ; return the amount of entites erased
  amt
(defun fx-make-layer-list (/ ent l_name entlst)
;;; generate a list of layer names based on user selection
;;; and returns that list
  (while
    ; while user is selecting something continue loop
    (setq ent (car (entsel "\nSelect Item on Layer: "))); test
    ; extract layer name from selected entity
    (prompt l_name); output the layer
    (if
      ; make sure the layer isn't already in the list
      (not (vl-position l_name entlst)); test
      ; if not then add it to the list
      (setq entlst (cons l_name entlst))
Download del-layer.lsp 3.44 KB
See the original topic for more details.
