Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 35
  1. #11
    Forum Newbie
    MEP 2010
    Aug 2009
    6
    I tried that code, but it just makes AutoCAD MEP close completely when finished opening.
    As far as the drawing1.dwg closing when you opening an existing drawing, not on my machine, if that's an option that would work to, but drawing1.dwg stays open and I have to close it manually..
    Any other suggestions?
    Thanks guys
  2. #12
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by AirSchatz View Post
    Thanks guys
    did you try the one i posted, it will check if the sdi mode is set to 0, if not, it will not continue and try to close the drawing.
  3. #13
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Idea
    Then something is modifying the drawing at startup. As soon as AutoCAD opens with drawing1.dwg - type in DBMOD at the command line. If it's not zero (0), then something is modifying the drawing.
    If DBMOD = 0 AND you start another drawing or open an existing one, then "drawing1.dwg" closes.
    If DBMOD /= 0 AND SDI = 0, AND you start another drawing or open an existing one, then "drawing1.dwg" stays open.
    If DBMOD /= 0 AND SDI = 1, AND you start another drawing or open an existing one, then you will be prompted to save "drawing1.dwg".
    R.K. McSwain
    CAD Panacea | twitter
  4. #14
    Forum Newbie
    MEP 2010
    Aug 2009
    6
    Quote Originally Posted by alanjt View Post
    I did try that, but when I open ACAD, it loads up then when the drawing1.dwg would the whole program just shut down. But then again, maybe I put the code in the wrong place....I inserted at the bottom of of the acad2010doc.lsp. I couldn't find the acad.lsp. Also, this is a AutoCAD MEP 2010 programs.
    Thanks for your help
  5. #15
    Forum Newbie
    MEP 2010
    Aug 2009
    6
    Quote Originally Posted by rkmcswain View Post
    the DBMOD = 20 (read only)......what does that mean?
  6. #16
    Civil 3D 2013
    Apr 2008
    6,199
    maybe something like this?
    Code:
    (and (eq (getvar "dwgname") "Drawing1.dwg")
         (zerop (getvar "sdi"))
         (if (zerop (getvar "dbmod"))
           (command "_.close")
           (command "_.close" "_y")
         ) ;_ if
    ) ;_ and
  7. #17
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Idea
    You can find all the system variables in HELP.
    A DBMOD value of 20 means that the view has been modified and a database variable has been modified.
    R.K. McSwain
  8. #18
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Idea
    First off, "acad2010doc.lsp" is executed every time a drawing is opened. Secondly, that file "belongs" to AutoCAD, meaning that it can be overwritten by reinstalls, service packs, upgrades, etc. Anything you put in here will probably be lost someday.
    "Acad.lsp" is only executed at application startup (assuming ACADLSPASDOC is not changed from its default value of zero), and is "owned" by the user. AutoCAD will never touch this file, it's under your control. Because it's a user file, you have to create it. It doesn't exist OOTB.
    R.K. McSwain
  9. #19
    Forum Newbie
    MEP 2010
    Aug 2009
    6
    That makes sense....The Acad.lsp you are talking about, is that the same as Acad2010.lsp? That was the only other lsp file in the support folder.
    Thanks for the help guys, this forum rawks.....
  10. #20
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    No! acad2010.lsp is "owned" by AutoCAD also.
    "acad.lsp" and "acaddoc.lsp" are the USER equivalents to "acad2010.lsp" and "acad2010doc.lsp" There is just no reason to edit the latter two files.
    See: http://usa.autodesk.com/getdoc/id=TS21336
    R.K. McSwain
  1. Replies: 0
    Last Post: 3rd Dec 2007, 05:51 am
  2. Book to start 3-dimensional drawing?
    By therock005 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Nov 2007, 01:57 pm
  3. Is autocad 2000 the program to learn autocad drawing skills
    By New2CADmike in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2006, 09:34 am
  4. i need to start
    By lonescat in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2004, 06:10 pm
