Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2007
    Feb 2008
    4
    Smile How to remove hatch function
    Hello everyone,
    I'm new member and beginer in CAD also. I have a file that the object already "hatch" and now I want to remove that hatch to edit the object. Is it possible to do that?
    Thank you
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,866
    Just select the hatch and delete it. If the hatch is on a separate layer, you could just turn off that layer, if you just want the hatch out of the way while editing.
    Super Member Ritch7's Avatar
    AutoCAD 2016
    Jan 2008
    Norfolk, United Kingdom
    552
    hi bnmphuong,
    do you mean you have a drawing that has a hatched area? and you wish to remove the hatching completely? (because thats fairly simple) or you do you mean something else?
    Forum Newbie
    AutoCAD 2007
    Feb 2008
    4
    Thanks everyone. I've attached my file to show clearly my question (before (1) and after (2) hatch). the file is already save and now I want to edit (2) --> (1). I try many way but It does not work.
    http://www.megaupload.com/?d=W6EV4BER
  5. #5
    Super Member
    AutoCAD not applicable
    Jul 2007
    639
    Sorry to be the bearer of bad news, But the person who created that drawing didn't do the best job...
    You can turn the hatch off (even though its on the same layer as line work)
    with FILL -> OFF
    however the hatch is really not a complete hatch see pic, the left over hatch, is actually lots of lines (see circle pic)
    you will have to delete the lines individually or by `fence' selection.
    Also you can attach drawings here see `Manage attachments' in the addition options window below the thread composition window
    , as long as the .dwg file is less than 250 kb
    If at first you don't succeed, then maybe failure is more your style.
  6. #6
    Forum Newbie
    AutoCAD 2007
    Feb 2008
    4
    Smile
    Thanks PS_Port but I try using fill --> off, it's not working. Anyway, can you show me more detail steps with the example below.
  7. #7
    Super Member
    Jul 2007
    639
    Sorry, I forgot to say regen at the end..
    O.k. just checked this works in your sample2 drawing
    at the command line.
    Command: fill
    Enter mode [ON/OFF] <ON>: off
    Command: regen
  8. #8
    Forum Newbie
    AutoCAD 2007
    Feb 2008
    4
    Oh good. Thanks very much.
  9. #9
    Full Member
    Bill W's Computer Details
    Windows 7
    Construction
    Bill W's Discipline Details
    Retired mechanical and civil engineer, 40 years designing and building paper mills
    Construction
    Design, project engineering, construction management, mainly designing/building wood products plants and paper mills. Now retired and have been doing volunteer work updating facility drawings for government agencies like state parks and recreation.
    AutoCAD LT 2011
    Sep 2013
    Olympia WA USA
    42
    Well, I should have known, jut select and delete!
  10. #10
    Full Member
    Windows 7
    Construction
    Construction
    AutoCAD LT 2011
    Sep 2013
    Olympia WA USA
    42
    Default Hatch covers some lines ?
    For some reason when I apply solid, light colored hatch to an object, the bounding lines disappear, as if hidden behind the hatch color. Also, I had two centerlines drawn on the object. When I applied the hatch, one centerline disappeared, the other remained! The hatch is just a light tan solid color. Any ideas?
    Thanks
    Bill
  1. How do I remove a Macro
    By Bogbadbob658 in forum AutoCAD General
    Last Post: 12th Jun 2008, 11:13 am
  2. Can't remove objects
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jan 2008, 12:17 pm
  3. how to remove plotstamp?
    By nivradolobo in forum AutoCAD Drawing Management & Output
    Last Post: 26th Dec 2007, 03:14 pm
  4. layers i cant remove
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 20th Oct 2006, 02:53 pm
  5. Remove edges?
    By Random1 in forum Autodesk Inventor
    Last Post: 16th Apr 2006, 03:24 am
