Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Junior Member
    AutoCAD 2007
    Feb 2008
    11
    Question creating a complex linetype with shape
    I'm trying to create a linetpye .The line needs to be continuous with a solid(not hollow) circles at distances.This would be the same as FENCELINE1:
    *FENCELINE1,Fenceline circle ----0-----0----0-----0----0-----0--
    A,.25,-.1,[CIRC1,ltypeshp.shx,x=-.1,s=.1 ],-.1,1
    but with filled-in circles.for example circles should be hatched or colored.
    An image of desired linetype is attached.
    Any help would be great.Thanks in advance.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Shapes can't have a solid fill/hatch. You can simulate the fill with closely spaced lines.
    Or use text instead of a shape; e.g. use the font file Arial with the character \U+25CF
    Junior Member
    AutoCAD 2007
    Feb 2008
    11
    Thanks a lot for your concern
    I could do this by drawing several circles with same center near each other, which resemble a filled circle as you said.Then I made a shape file of these using the menu Express>Tools>Make Shape , which gives *.shp and *.shx file.I called this file in a *.lin file and it worked
    I don't know enough to perform what you said about using fonts, cause I am not that familiar and I've not worked with fonts.
    Anyway it solved
    Full Member
    AutoCAD 2010
    Dec 2007
    93
    Quote Originally Posted by lpseifert View Post
    That doesn't seem to work.
    If I have this in my linetype file:
    *telephone,----O----O----
    A,200,-0,["\U+25CF",Arial,S=0.20,R=0.0,X=-0.1,Y=4],200,["\U+25CF",Arial,S=0.20,R=0.0,X=-0.1,Y=-12]
    The result is:
  5. #5
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,015
    Try this (uses Arial font):
    Code:
    ;*PROP-FENCE-CL,----0-----0----0-----0----0-----0-
    ;A,.476777,["\U+25CF",LT-P,y=-.0275,s=.06],.00197,-.037923
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  6. #6
    Full Member
    AutoCAD 2010
    Dec 2007
    93
    That gives me an error trying to load the linetype file:
    "Bad definition of PROP-FENCE-CL at line 142" (the second line from your code)
  7. #7
    Civil 3D 2011
    Apr 2008
    6,015
    Quote Originally Posted by ChrisCMU View Post
    Because the textstyle doesn't exist. It's just a textstyle with Arial font. Just replace "LT-P" with "Arial".
  8. #8
    Full Member
    AutoCAD 2010
    Dec 2007
    93
    so do I need to create a text style called LT-P with Arial as the font?
  9. #9
    Civil 3D 2011
    Apr 2008
    6,015
    or just replace it with Arial.
    Code:
    ;A,.476777,["\U+25CF",ARIAL,y=-.0275,s=.06],.00197,-.037923
  10. #10
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    You can make all sorts of "text-based" linetypes with the various shapes that are in wingdings.ttf, webdings.ttf, etc. Here are a couple...
  1. Complex Shape Design (AOTC)
    By Lazer in forum Autodesk Inventor
    Last Post: 16th Nov 2007, 09:06 pm
  2. creating complex linetypes
    By BUFF_dragon in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2007, 11:41 pm
  3. Replies: 2
    Last Post: 5th Oct 2006, 01:14 pm
  4. Using " in a complex linetype
    By Barry Clark in forum AutoCAD General
    Last Post: 2nd Aug 2006, 06:58 pm
  5. creating shape files are causing headaches
    By PETERHAY1 in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jul 2004, 02:14 pm
