Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Full Member SilverTiger's Avatar
    SilverTiger's Computer Details
    Windows 7
    Manufacture
    SilverTiger's Discipline Details
    I work at Dana, assembling truck axles
    Manufacture
    AutoCAD 2012
    Feb 2008
    Evansville, IN
    32
    Default Recover from .sv$
    How do I change the file extension in an autosave file from .sv$ to .dwg AND have it successfully open up without it saying "invalid file fromat"? I'm currenty using ACAD 2005 Full version on Windows XP.
    File type: AutoCAD Autosave Drawing.
    Things I've already tried:
    1. Renamed the file in Explorer, only to find out that it just tacked the .dwg directly onto the file name in front of the .sv$ extension (blabla.dwg.sv$)
    2. Opened the file in Notepad and successfully changed the extension, but AutoCAD said it was an invalid file format when I tried to open it.
    3. Went to the file's properties and changed the "Opens With" option to AutoCAD which I knew wouldn't work but tried it anyway.
    Any suggestions?
    ST
    Senior Member architecture68-raff's Avatar
    ADT 2005
    Nov 2006
    Chicago, IL
    159
    To rename the files correctly in explorer, go to Tools -> Folder Options and then go to the view tab. Uncheck the option "Hide extensions for known file types". You should now be able to change in explorer correctly to blah.dwg instead of blah.dwg.sv$
    I would recommend going that route as opposed to opening in Notepad and renaming.
    Windows 7
    Manufacture
    Manufacture
    AutoCAD 2012
    Feb 2008
    Evansville, IN
    32
    Thx! It worked! Whew...
    ST
    Junior Member Stangman's Avatar
    AutoCAD 2007
    Feb 2008
    Iowa, US
    19
    I like to also change the location of my automatic saves to somewhere more accessible. In options, under file tab just change the Automatic File Save Location. You might already know that, but just figured I'd add it in.
    Fueled On Adrenaline
  5. #5
    Windows 7
    Manufacture
    Manufacture
    AutoCAD 2012
    Feb 2008
    Evansville, IN
    32
    Yeah, I'll try that. Thanks.
    ST
  6. #6
    Junior Member
    AutoCAD LT 2004
    May 2009
    Indy
    10
    Hi guys...
    just to piggy-back onto the original question, how do I make that Windows Explorer mod in Vista? I've tried plinking around in Explorer but can't find it.
    I've got this same problem.
    I am using LT 2004.
    Thanks!
  7. #7
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    did you do the step in post 2? This is still included in Vista as far as I can remember.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  8. #8
    Junior Member
    AutoCAD LT 2004
    May 2009
    Indy
    10
    I just found the settings I was looking for in Explorer.
    I clicked on "Computer" (in Explorer)... then hit "Organize"... select the "View" tab.
    it's in there. Got my files.
    thanks
  9. #9
    Junior Member
    AutoCAD LT 2004
    May 2009
    Indy
    10
    But now i've got another question, as I battle futility.
    Are the sv$ files wiped out of the TEMP when you shut your PC down?
    I can only find sv$ files from this week, I had my machine shut down over the weekend.
    thanks.
  10. #10
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    More information can be found from this excellent BLOG site - http://cadpanacea.com/node/15
    Life's constantly changing - keep up or get left behind
  1. Recover a Drawing File
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jul 2009, 12:03 pm
  2. Autocad 200 recover drawing after crash
    By andyboy in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jan 2007, 06:22 pm
  3. RECOVER command (another "I used to" question)
    By brassworks in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2006, 05:14 pm
  4. Help with fatal error...I can't seem to recover drawing file
    By ccfrosty in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2005, 06:01 pm
