Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Default Dynamic Block Linked with Field
    Ok so i've created this dynamic block (see attached) which when you insert at 0 on the 'Y' axis and copy it up it displays the different levels using a field link to the 'Y' axis. Once you type regen that is. This can be used on elevation drawings showing floor levels and datums.
    Now im fairly new to fields and all i want to do is amend this one already in place, rather than showing mm dimensions i want metre dims which is how you normally datum floor levels. Can someone point me in the right direction? Rather that starting all over again there must be an edit field command!
    Any help will be greatly appreciated.
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    I meant to look at this before I left work and it's too late now so I'll have a look tomorrow. Just to clarify though, are you wanting the number you have divided by 1000 or something else? If you just want a simple sum done you can do it through the block editor. Right click on the attdef and use the Insert Field method. In the box that you build your field in you can insert a formula.
    If you can find one of my TerminalRail blocks that I've posted here from time to time you MAY find one with a formula field. I divide the length of rail by the terminal width (and format it to an integer) to show the number of terminals. On more recent ones I also factor in the inserted scale so that they can be used in imperial drawings!
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    have a look in this thread for my attachment (2nd post)
    http://www.cadtutor.net/forum/showthread.php?t=19880
    Dave
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    open the "field" in the text editor and right-click over the text and choose edit field (or crtl+f)...
  5. #5
    Construction
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Sorry meant to say im on 2006... crtl + f doesn't seem to work.
    dbroada - yes wanting to devide it by 1000 so it would look like Metres. not sure how to do formula i will have to have a look later. Thanks
    AutoCAD 2010
  6. #6
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    Quote Originally Posted by JBullseye74 View Post
    I have a picture of my screen to show you how I've done it but I can't attach a jpg at the moment.
    Dave
  7. #7
    Construction
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Quality cheers i look forward to seeing it.
    AutoCAD 2010
  8. #8
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    I've had to cut this down quite a bit - hope it still gives you sufficient information
    Dave
  9. #9
    Construction
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    ok Thanks i've got this table up but im not able to make it work.
    AutoCAD 2010
  10. #10
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    OK, I've finally got round to looking at your block. Open it up using BEDIT and explode the text block. These should be ATTDEFs at this stage.
    Dave
  1. Using a Field as an Attribute in a Dynamic Block
    By Dave-CSMW in forum AutoCAD General
    Last Post: 29th Sep 2008, 11:09 pm
  2. Dynamic Block / Field for FFL
    By JBullseye74 in forum AutoCAD General
    Last Post: 10th Dec 2007, 10:35 am
  3. Create a field linked to an object
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 7th Sep 2006, 02:02 pm
  4. Define Block Attributes with field name
    By gnotnoel in forum AutoCAD General
    Last Post: 20th Jun 2006, 06:57 pm
  5. Link a block to a field to a table
    By powerman in forum AutoCAD General
    Last Post: 15th Jun 2006, 04:42 pm
