Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: deter.vlx
    Super Member chrisdarmanin's Avatar
    AutoCAD 2009
    Feb 2006
    Malta
    524
    Default deter.vlx
    you can find it here
    http://www.dotsoft.com/freestuff.htm
    has anyone ever used it?
    this is what it says on the site description:
    A strong deterrent to prevent changes (by others) to the drawing because it can’t be exploded or refedited. Be careful to use only on a copy of your drawing you intend to send to others!
    would it be a bad idea to send it to other people like that? (rather than pdf of maybe dwf?)
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    If you're thinking of doing it I'd recommend letting the end user know in advance that the drawing cannot be editted by normal means. You're basically sending them a "screenshot" is one way of looking at it.
    Is there a particular reason why you feel going this route is called for? Has a particular end user been revising and reusing your CAD drawings or is it more a matter of protecting your intellectual property?
    AutoCAD 2009
    Feb 2006
    Malta
    524
    partly to protect intellectual property. most people would want a dwg rather than a pdf because they cant edit, print (since its better with acad) or measure accurately. every time i sent drawings in dwf format no one knew what to do with it and they were too lazy/stupid to download and install dwf viewer so i thought this is a good way to protect all my work such as the blocks and all the standards i use and still send the .dwg
    dwf would be the most ideal imho.
    what are the other means? or there aren't?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,639
    Exclamation
    Quote Originally Posted by chrisdarmanin View Post
    Using lisp, vba, or arx code to "undo" what "deter" does.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    If "they are too lazy/stupid" to use DWF Viewer then "Deter" may be just enough to stop them in their tracks. I can't see them trying to use any one of the options R.K.M. has mentioned.
  6. #6
    AutoCAD 2009
    Feb 2006
    Malta
    524
    hehehe yes exactly what i thought
    Quote by George (AWDC Malta President) about Land Rovers:
    "Trid ittiha xebgħa mazza ta' bla raġuni"
    Translation: You have to attack it with a mallet for no reason at all"
  7. #7
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    10 minutes need to break Deter
    Code:
    (defun c:antideter(/ mIns mBl blCol actDoc oLst oArr)
      (vl-load-com)
      (if
        (and
          (setq mIns(entsel "\nSelect minsert block > "))
          (= "AcDbMInsertBlock"
             (vla-get-ObjectName
    	   (setq mIns(vlax-ename->vla-object(car mIns)))))
        ); end and
          (setq mBl
    	     (vla-Item
    	       (setq blCol(vla-get-Blocks
    		 (setq actDoc(vla-get-ActiveDocument
    		   (vlax-get-acad-object)))))
    	       (vla-get-Name mIns))); end setq
          (vlax-map-collection mBl
    	'(lambda(x)(setq oLst(cons x oLst))))
          (setq oArr(vlax-make-safearray 9(cons 0(1-(length olst)))))
          (vlax-safearray-fill oArr oLst)
          (setq oVar(vlax-make-variant oArr))
          (vla-CopyObjects actDoc oVar(vla-get-ModelSpace actDoc))
          (vla-Delete mIns)
          ); end progn
        ); end if
    ); end of c:antideter
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    If a person doesn't have the intelligence, time, or desire to use DWF Viewer what makes anyone think the same person is going to try to break Deter? You could give them 10 minutes, a half-day or an entire week, it just wouldn't matter.
    Maybe something like this would be a better option:
    http://www.cadlock.com/
  9. #9
    Super Member
    AutoCAD 2007
    Aug 2003
    Livingston, Scotland
    995
    ... every time i sent drawings in dwf format no one knew what to do with it and they were too lazy/stupid to download and install dwf viewer ...
    Then EDUCATION of your end user is the key..... NOT screwing around with the drawing
    ResourceCAD.... the Resource for your CAD Solutions
  10. #10
    AutoCAD 2009
    Feb 2006
    Malta
    524
    Quote Originally Posted by hendie View Post
    that is sometimes difficult. they always have some excuse about not having time to install the dwf viewer or its not working. sometimes they barely know how to use a computer...
