Poll: Command Line vs Toolbars
Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 79
  1. #11
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    I hate toolbars. I am a keyboard junkie. That's why I get complimented on how fast I am all the time from co-workers and clients. My brain knows where the key is and I'm never scanning over a hundred icons to get the tool I want - And I have a decently modified *.PGP file as well.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  2. #12
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,096
    I use both as well as the right-click. Right now I only have 3D Toolbars up and my 3D workspace activated. Most 2D stuff I use the command line or right-click.
    When I started out in DOS I would do almost everything with the keyboard, no mouse no digitizer. Then in R14 I started using mostly just toolbars, because I loved making custom buttons.
  3. #13
    Full Member 97catintenn's Avatar
    Construction
    97catintenn's Discipline Details
    Small Construction
    Construction
    Architecture 2014
    Oct 2007
    Johnson City, TN USA
    91
    I would be command only if I knew all the commands. I'm still a newbie and learning. I have developed a small custom tool bar for the commands that I do not know.
  4. #14
    Full Member
    AutoCAD 2007
    Jul 2006
    33
    Command line except for layers and layers II. Oh and draw order tool bar.
  5. #15
    Senior Member
    AutoCAD 2002
    Apr 2007
    North Carolina
    188
    I use both
    Jon ~
  6. #16
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    Quote Originally Posted by Autocad Assassin View Post
    ... What got me thinking about the issue is that i recently injured my left hand (keyboard entry) and have to use toolbars for the time being. This is my first day and it feels extremely slow leaving the drafting area everytime i need a new command. any tips?
    yep
    I think I'm the only one who's voted for predominantly toolbars, but I always make my own for each job I take, and can't take one with me as each job requires a different set of most used commands
    I also put together new buttons which run through sequences quickly and easily - the standard one being 'zoom extents-purge-save-close' - so I never forget to purge (I mostly use LT so don't hassle me with Lisp advice )
    this toolbar is then not located outside the drawing area, but squashed into a square (use dividers to make it do this), and parked a little off to the top right hand corner from the centre of the screen - saves on RSI
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  7. #17
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Wink
    Quote Originally Posted by Strix View Post
    yep
    So far strix the only one who has addressed main part of the origianl question.
    Though It is nice to know what all r using but original poster's main question is how to use toolbars more effectively, that's what he is stuck with at the moment bcs of injury.
    For me i can say i use both equally. i use toolbars a lot. & so i am posting screenshot of my workarea. Let me know if you need more explanation on toolbars.
    with practise i also know where to find any command from drop down menu at the top.
    so just explore each dropdown menu few times & practice, you will get use to it after sometime.
    all th best
  8. #18
    Junior Member
    not specified
    Jul 2006
    23
    I agree that it's frustrating to watch someone use toolbars. I find it specially so when I'm instructing them in a procedure.
    "move that object over real quick, UGH JUST HIT 'M' AND ENTER!!!"
    Actually Ive switched to keyboard & mousing w/ the right hand because I just cant take the toolbars. Maybe i need to hire a little kid to hit the keys for my left hand.
    As far as my toolbars go, ive got a Save&Purge&Audit&Close button, a few that drop in doors/windows and label them at the same time, 2 for drawing order, and 1 w/ my snap preferences.
  9. #19
    LElkins
    I use command line only (with the exception of my vba custom tool toolbar) when working in pure AutoCAD, but then obviously command line plus palettes when working with ADT/ACA.
    Can not stand toolbars, far too much time wasted, and don't fancy brining on any injuries any sooner by constantly moving back and forth to the move/copy/etc icon.
  10. #20
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,096
    Sounds like you need to customize (customise?) your right-click menus.
  1. Selection of a line from Command line!
    By devouring in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 03:16 pm
  2. OTRACK command fails when using floating command line
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 3rd Feb 2007, 02:40 am
  3. Who Else Wants To Know About The Line Command?
    By josvandoorn in forum AutoCAD General
    Last Post: 26th Aug 2006, 03:38 am
  4. Who Else Wants To Know About The Line Command?
    By josvandoorn in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2006, 03:37 am
  5. command line
    By kd in forum AutoCAD Beginners' Area
    Last Post: 8th Feb 2006, 06:11 am
