Hmmm... we've had this question before & I'm not sure we came up with a watertight solution... I'll see if I can find it...
is there a way to exclude xrefs from the selection? maybe a lisp of something similar?
what i need is to snap to the xref but not select it and accidentally modify it. locking the xref layer works but still i dont want it selectable... maybe i am asking too much...![]()
Quote by George (AWDC Malta President) about Land Rovers:
"Trid ittiha xebgħa mazza ta' bla raġuni"
Translation: You have to attack it with a mallet for no reason at all"
Ah... here it is...
http://www.cadtutor.net/forum/showthread.php?t=19211
hmmm... thanks... useful thread. i'll try saving the xref as dwf then xreffing the dwf and set imageframe to 0. i'll tell you how it goes later since i'm a bit busy to experiment
this is another similar thread
http://www.cadtutor.net/forum/showthread.php?t=13272
No one has found the exact solution yet![]()
but u can also look at this thread.
may be we need to add this to augi wishlist. i have heard about ti from this forum only
worked great! and i could snap to it, and it didn't bog the computer down
only problem is that i couldnt switch off layers... even though i included the layer info in the dwf
I believe this is on the current AUGI wishlist, so You need to sign up and do some voting.
