Results 1 to 5 of 5
    Super Member chrisdarmanin's Avatar
    chrisdarmanin's Computer Details
    win 10
    HVAC
    chrisdarmanin's Discipline Details
    Building Services Draughtsman
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    Default rotation parameter (dynamic blocks)
    do you have to add it before everything else? if i add things before it everything starts acting crazy. for example i cannot stretch it where i want etc...
    is there i sequence i should follow to add parameters?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I have not read anything that says anything about doing things in order, but like you, I have found instances where doing things in a certain order have worked out better.
    Senior Member
    JeepMaster's Computer Details
    Windows 7 64-bit
    HP
    Core i7
    32GB
    27" Dell 2709W
    Electrical
    JeepMaster's Discipline Details
    Electrical
    Electrical
    Revit 2016
    Mar 2006
    Alberta, Canada
    293
    I've created many dynamic blocks, and as long as you select the right stuff to rotate, it shouldn't matter.
    win 10
    HVAC
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    later i'll post an example. on a certain block i was moving two lines away from the centre, with one linear parameter, then i added a rotate parameter and action.
    when i saved the block and rotated then moved the lines they mover at an offsetted angle rather then perpendicular.
    if i made the parameter the other way round it worked perfectly
    l'll post an example later cos i'm busy. maybe i'm missing something
  5. #5
    win 10
    HVAC
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    i managed to replicate the problem and foud out what i was doing wrong
    when i was selecting the objects for the rotate action i was also selecting the move action which messed things up
  1. Dynamic Block Rotation
    By RFRUSSO in forum AutoCAD Drawing Management & Output
    Last Post: 31st Mar 2014, 04:23 pm
  2. Attribute rotation in dynamic block
    By JeepMaster in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2013, 03:12 pm
  3. Hide a part of Dynamic Block (Visibility Parameter)
    By Little Bandit in forum AutoCAD General
    Last Post: 11th Apr 2012, 08:34 pm
  4. dynamic block: bifold doors W/ flip parameter woes...
    By hazardman in forum AutoCAD General
    Last Post: 30th Aug 2007, 01:36 am
  5. Dynamic Blocks?
    By The Nickster in forum AutoCAD Drawing Management & Output
    Last Post: 27th Dec 2006, 09:11 pm
