Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Moving Autocad
    Full Member
    AutoCAD 2008
    Feb 2008
    New York
    58
    Default Moving Autocad
    I have autocadLT 2005 on an older computer, upgraded from 2000i. I was wondering what I should do to move it to a new computer. I'm upgrading 2005 to 2008. Do I have to uninstall 2005 then go to the new computer and install 2000i then use the 2005 upgrade on that, then install the 2008 upgrade? What about registering it? How does this work after the uninstall?
    Thanks for the help.
    Senior Member azzro10's Avatar
    azzro10's Computer Details
    XP Pro
    AutoCAD 2010
    Dec 2007
    Melbourne, Australia
    311
    If you have your serial number that came with 2008 just install 2008 on your new computer and follow the prompts
    You can get it jumpin' You can get it pumpin' You can get it chasing a cow. Matter o' fact, I got it now.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    If 2008 was an upgrade, won't the software first look for the 2005 Autocad .exe file?
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    As Azzarro said, since can't remember when and even then only LT had any backwards checking: Upgrades are totally new products and DO NOT need to have a previous version installed.
    The other thing is that once you've installed and start registering it, you'll be asked for the s/n of the older version...
    Good Luck!
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
  5. #5
    Full Member
    AutoCAD 2008
    Feb 2008
    New York
    58
    Quote Originally Posted by azzro10 View Post
    Do you not need the previous version installed on the computer? If you can just install the 2008LT upgrade on the new computer, it will install the full 2008LT software? I'm guessing the only way this is possile is if you are already registered with 2005 and it detecs that then just installs the full 2008LT. Am I understanding this right?
    EDIT: So I understand right? 2008 upgrade is reallly the full version but to access it you need previous serial #'s?
  6. #6
    AutoCAD 2009
    Jul 2007
    Finland
    340
    No,
    as far as I know (I'm in EMEA, not USA) the LT as well as the full product are since "I cannot remember" full installs even when bought as upgrades. Autodesk initially "trusts" you to remove the old one when you install the new one. And BSA takes care of the rest by "listening" in on our conversations here...
    Cheers,
    Petri
  7. #7
    Full Member
    AutoCAD 2008
    Feb 2008
    New York
    58
    Well I think you got confused with what I was saying, this whole time I have been talking about LT. What I meant was that the full install of LT is on the upgrade.
  8. #8
    XP Pro
    AutoCAD 2010
    Dec 2007
    311
    I havent had any experiece with LT but i would have thought that they would send you a "full version" of the "LT version" (that sounds a little confusing)
  9. #9
    Full Member
    AutoCAD 2008
    Feb 2008
    New York
    58
    Or you could say it as a full install of LT on an upgrade disk. I think I will be fine once 2008LT gets here.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    I changed my mind. The install is on a brand new computer. AutoCAD will prompt you for the previous version's serial number. It shouldn't be a problem.
  1. Moving blocks
    By SIMON1511 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Oct 2007, 03:05 pm
  2. Moving to AC 2007
    By youflyifix in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2007, 11:23 pm
  3. Moving Objects
    By Keith1211 in forum AutoCAD Beginners' Area
    Last Post: 1st Feb 2006, 09:35 pm
  4. Moving Blocks
    By mrbob2 in forum AutoCAD General
    Last Post: 10th Jan 2006, 09:03 pm
