Results 1 to 5 of 5
Thread: Text thickening
    Forum Newbie
    AutoCAD LT 2007
    Feb 2008
    8
    Default Text thickening
    When i copy text to a new position the text becomes "thicker" I am using arial and century gothic font.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Are you snapping the text to an endpoint or something? If the Z value of your text changes, the text will appear thicker. Make sure your text is at Z0.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Forum Newbie
    AutoCAD LT 2007
    Feb 2008
    8
    I am snapping to an end point of an object as i have multiple plan layout so i am aligning the text in the same positions. The Z value of my text is 0 but the problem still occurs.
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    When we swapped from SHX fonts to TTF fonts, all the text suddenly appeared thicker. You get used to it, but it does plot correctly.
  5. #5
    Forum Newbie ascorah's Avatar
    AutoCAD LT 2009
    Nov 2007
    2
    Hi guys,
    I can't seem to find a solution to this problem. As Rory47 said, Z values are 0 but the text still appears thicker when copying to a point of an object. Note, this problem does not occur when copying text to open space i.e. not snapping the end point. Please answer if you know what to do. Rory, have you figured it out?
  1. converting lower case text to to capital text
    By REIVAX in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2009, 11:36 am
  2. Text appears to be faded in Text Formatting
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2007, 07:07 pm
  3. Dimension text separator displayed at the beginning of text
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 12th Sep 2006, 02:51 am
  4. Replies: 0
    Last Post: 6th Sep 2006, 09:19 am
  5. export multiple text and the coords of the text????
    By jman340 in forum AutoCAD General
    Last Post: 28th Apr 2005, 08:00 am
