HI,
I need a lisp file that will select an object's layer and switch all the other layers off except the objects that have been selected.
I also need another lisp file that will repeat the last layer works command in reverse. Hence when I have selected the layer and switched off all the other layers the new lisp file will switch back on the previous layers.
Thanks.
