Is Carlson built onto AutoCAD 2006?
Hi there I am fairly new to the site.
I have a slight problem with the linetypes. They are quite basic just a line space then arrow or zig zag. But randomly the odd one will have the arrow or zigzag offset itself from the line and change direction. I need to know how to rectify this and make the linetypes show the arrows in the right direction. I have tried redraw, match properties, regen and copy but the same problem keeps happening. I am using carlson 2006 which is similar to cad.
Any help would be greatly appreciated.
there just a built on. http://www.carlsonsw.com/PL_CS_GIS.html
Is it just because the occasional section of line is draw from R to L instead of L to R or vice versa?
Here's an example pic.
The line to the right with the arrow is wrong it should be like the "assumed line" one. I know how to alter the direction but its the linetype actually offsetting the arrow that I'm having problems with.![]()
Looks like the linetype scale applied to the particular entities (in properties) is different here... could that be causing the error?
Can you make the pic a little larger? Have you checked that both have the same LTSCALE?
Try posting the .lin file for that linetype.
What AutoCAD version are you using?
