Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Vaker
    Default How to print white??
    I assigned white to a solid surface, but when I plot preview it's gray...
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    The colour white (7) will always print as black from AutoCAD. Traditionally, the drawing background colour has always been black and therefore, black background = white paper and white objects = black ink.
    Of course, you can change your model space background to white if you wish. In that case, all your "white" (colour 7) objects will appear black. This may be more logical for you if you are unused to AutoCAD although most users seem to prefer the black background - I know I do, it's much easier on the eye.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Vaker
    No, no that's nto what I mean. I assigned the solid a white color but not absloute white, and when I view it in the layout it's grey, even when I preview the plot. I want to have the solid's color be white when I print it.
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    So you assigned the solid a near white (grey) colour and when you preview it looks grey? OK but you want to print white ink on white paper?
    Can you tell me why you want to do this and then maybe we can find a better way of doing it. Are you trying to mask a part of your drawing?
  5. #5
    Vaker
    Ok I'm trying to do this so that when I print an Isometertic of this it won't show lines behind the building.
    Example. I wanted to assign the aqua markerd face white so that it could hide the lines that are labeled with the red arrows.
  6. #6
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    OK. All you need to do is make sure that the rectangle marked with aqua dots is either a 3D Face or a solid. Then, when you print, make sure that you use the "hidden" option. This is different, depending on whether you're plotting from model space or paper space. If plotting from model space, look for the hide lines option in the plot dialogue box. If plotting from paper space, you need to set "hideplot" for each viewport.
    If you do this, you will not see the lines behind your wall, they will be hidden. No need to plot white
  7. #7
    Vaker
    Ok, I'm going to test it out ,and post shortly the results
  8. #8
    Vaker
    Ok I saw the hidden option in model mode, but when I try to print thru layout I only see these options :
    Plot Objectline weight
    Plot with Plot styles
    Plot with paperspace last
    Hide Paperspace object
    I tried checking them all, but when I preview it it still shows the color of the solid face
  9. #9
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    What is the shade mode in the viewport you are trying to plot. Shademode should be wireline for this to work correctly (although hidden sould also work).
  10. #10
    Vaker
    When I try to print the layout the shade mode is greyedout, and cannot be selected :-/
