zemoe12 Posted March 4, 2008 Share Posted March 4, 2008 I'm using Autocad 2008 and when I move text that I've applied wipeout to, the wipeout box stays behind. I don't remember the parameter to check so the wipeout box stays with the text....(brain cramp)....does anyone recall this. It exists. thnx, zemoe12 Quote Link to comment Share on other sites More sharing options...
CarlB Posted March 4, 2008 Share Posted March 4, 2008 "tframes" command will toggle the wipeout so you can see/select it. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 4, 2008 Share Posted March 4, 2008 If you made the wipeout using Textmask, setting Pickfirst to 1 (or 3) should fix it. Ctrl+H will do the same thing (toggles Groups on/off). Quote Link to comment Share on other sites More sharing options...
iccy Posted May 29, 2008 Share Posted May 29, 2008 I don't suppose there's a way of doing it in LT is there? TFRAMES doesn't work, nor does textmask. Any other way of turning the frames on? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 29, 2008 Share Posted May 29, 2008 Initiate the WIPEOUT command, then type F for Frames and then type ON. Quote Link to comment Share on other sites More sharing options...
iccy Posted May 29, 2008 Share Posted May 29, 2008 Nice one, thanks. Quote Link to comment Share on other sites More sharing options...
DUGEY007 Posted January 25, 2010 Share Posted January 25, 2010 Crl-h Or Pickstyle -1 That Will Fix Quote Link to comment Share on other sites More sharing options...
