Results 1 to 8 of 8
    Junior Member
    AutoCAD 2007
    Jan 2008
    10
    Default White text over black hatch
    I'm trying to create a block of a logo to use in the title box and I need to place white text on a black background. I've filled the background with a solid hatch which I've set as color no. 7, and the text I've placed on top and set it as color 255. It appears correctly on the monitor, but when printed the white lettering does not appear. I'm assuming this is because the printer can't print white over the black background, as opposed to it "cutting out" the text from the background. Is there a way to do this? The fill dosen't recognize the text as a boundary. If I create a jpeg in another program and insert it in the block, does the jpeg file become part of the block or does the block always refer to the file in a certain location (similiar to InDesign)? Thanks.
    I'm using AutoCAD 2008!
    LElkins
    use DRAWORDER and send the text to front. You shouldn't have any problem with this, I have done it before.
    Cheers
    Junior Member
    AutoCAD 2007
    Jan 2008
    10
    I've set the draw order and it displays correctly, I'm not sure if it is saving that way as when I open it again in the block editor it seems as if the order may have changed. It still does not print correctly.
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    you need to make sure that the *.ctb file you're using has colour 255 set to 255 and not black/7...
  5. #5
    Senior Member
    Architectural DT 2008
    Aug 2007
    Houston
    119
    The other possible issue is if yout .CTB file has lines set to merge, the white will merge with the background & poof no text.
    Our office keeps lines merge on as standard, we use screening in wall pochettes etc. Screened linework dosen't print correctly without mergeing.
    I have to say that autocad REALLLY dosen't handle white text very well. If it is a logo used often I'd be tempted to make the text an outline & fill around the outside.
    You never want to shoot yourself in the foot, Especially when it's in your mouth.
  6. #6
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    861
    Try using an RGB Color of 255,255,255 for white.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
  7. #7
    Full Member joewaianae's Avatar
    AutoCAD 2007
    Aug 2007
    Nebraksa
    89
    Quote Originally Posted by HiFiJr View Post
    The block its self needs to have the corrections. So what it says in the block editor is what it will show on the print out.
  8. #8
    Senior Member
    Aug 2007
    Houston
    119
    Have you checked the merge control under graffics in your plotter CTB? you need to have "lines overwrite" checked or you will get solid black no mater what.
  1. how do I print in black & white?
    By gib65 in forum AutoCAD Beginners' Area
    Last Post: 28th Jul 2008, 01:23 pm
  2. Printing white on black
    By bsanderson in forum AutoCAD Drawing Management & Output
    Last Post: 18th Dec 2007, 10:56 pm
  3. Printing white on black
    By NealV in forum AutoCAD General
    Last Post: 23rd Feb 2007, 09:12 pm
  4. Changing the text color on plot from black to white
    By David Banning in forum AutoCAD Drawing Management & Output
    Last Post: 12th Sep 2006, 04:16 pm
  5. White Text on Black Background?
    By afry in forum AutoCAD General
    Last Post: 9th Mar 2006, 10:03 am
