Results 1 to 4 of 4
    Full Member
    MEP 2008
    Feb 2008
    34
    Default Help with Macro Please
    Hi,
    I am using Autodesk MEP 2008
    I was wondering if it is possible to have a macro that will bring in a specific block "Roof Drain" from a specific drawing "C:\data\Blocks.dwg" and multiply this block by the "Annotation Plot Size"?
    I know i can make a macro using the command -insert, but when i use this command, it asks for the blocks name, the insertion point, the scale, and then it will insert the block into the drawing. so i am trying to find a way where the macro will insert the block into a drawing without any questions, and it will multiply the block by the drawings "Annotation Plot Size".
    Thanks in advance
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    All you need to do is have all the answers to the prompts in the Macro. If the block is annotative it should come in as annotative. I haven't tried the annotative part so not sure. If you will do a search, there have been a few threads on this several months ago with several macros to insert blocks in different ways.
    Full Member
    MEP 2008
    Feb 2008
    34
    The problem with an annotative block is that is will scale according to the annotation scale only and i would like it to scale according to the annotation scale and the annotation plot size.
    The reason for this: when i change the annotation plot size, i will like my blocks to scale automatically according to the annotation plot size without having to go into the blocks settings and manually change them.
    If you look at a schematic symbol, which is a block: if the schematic symbol has a width of 2mm, then it will be inserted into the drawing at a size of 2mm x annotation scale x annotation plot size.
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Such is the reason I use the Tool Palette and Design Center to insert blocks. I f i have time I will look into doing this with a Macro and see what can be done with all the Annotation stuff. NBC is the Annotation guru, maybe he will chime in.
  1. Macro Help
    By Thomas188 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jul 2008, 06:55 pm
  2. Run Macro in different Application
    By Kollargoll in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Sep 2007, 10:18 am
  3. Macro Question
    By matrix in forum AutoCAD General
    Last Post: 13th Mar 2006, 12:10 am
  4. help with toolbar macro
    By furnituremk'r in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2006, 03:29 pm
  5. Macro Help
    By dreese1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2005, 09:09 pm
