Closed Thread
Results 1 to 3 of 3
    Full Member kidoy's Avatar
    Inventor 2008
    Jan 2008
    australia, victoria
    30
    Default How to change the language setting? pls help...
    hello guys,
    pls hellp me to configure how to cahnge the default language settings of my inventor 11 ( i mean the word is in FREnCH i want it to be in ENGLISH) since the start of the installaion it was already in french i hope that upon installation there will be an language option but there is nothing so with the help of my friend i succesfully installed the program but the problem is continuous its all french settings so its hard for me to use it, i got my inventor 11 thru a torrent site and it was crack i think the sofware is fine just the language is in french...
    pls guys help me with this i am inventor user but not that good i used it on my job specially in piping, hope to here from you guys pls....
    thanks...
    kidoy
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Try calling this number and give them the information you have given here. 1-800-66267437
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    Quote Originally Posted by kidoy View Post
    You will receive no help from us, please phone the number JD gave you and tell them you are using a pirate copy!
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
  1. i can not change the layer's setting in layer toolbar
    By bobi in forum AutoCAD Drawing Management & Output
    Last Post: 11th Apr 2013, 04:38 pm
  2. How to change default setting for Linetype generation property
    By Proctor in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2008, 06:59 pm
  3. How to change AutoCAD Language
    By Safwah in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jul 2007, 12:26 am
  4. What setting do I need to change?
    By Silascat2 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2007, 05:55 pm
  5. ....change the default mirror setting?
    By MAXXPOWER71 in forum AutoCAD General
    Last Post: 22nd Aug 2006, 05:54 pm
