+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Full Member Matho's Avatar
    Using
    AutoCAD 2008
    Join Date
    Oct 2007
    Location
    Australia - Fremantle
    Posts
    25
    Default Fillet Command create cirlces
    Hi,
    I'm having a problem with the fillet command. I'm not sure what i'm doing wrong but most times when adding a fillet, it create a circle. The shape is that of a boat hull. I have attached an example. Your advise and thoughts are appreciated.
    Matho
  2. #2
    Senior Member azzro10's Avatar
    Computer Details
    azzro10's Computer Details
    Operating System:
    XP Pro
    Using
    AutoCAD 2010
    Join Date
    Dec 2007
    Location
    Melbourne, Australia
    Posts
    311
    Default
    its because your trying to fillet between a line and an arc so autocad doesnt know where to trim the fillet circle.
    You can get it jumpin' You can get it pumpin' You can get it chasing a cow. Matter o' fact, I got it now.
  3. #3
    Forum Deity
    Using
    not specified
    Join Date
    Jul 2004
    Location
    Anchorage, Alaska
    Posts
    2,074
    Default
    Fillet doesn't work as well on polylines as lines. I'd suggest exploding, fillet, join (pedit) to polylines when done.
  4. #4
    Computer Details
    Operating System:
    XP Pro
    Using
    AutoCAD 2010
    Join Date
    Dec 2007
    Location
    Posts
    311
    Default
    it will still happen when he explodes coz theres an arc involved
  5. #5
    Super Member
    Using
    AutoCAD not applicable
    Join Date
    Jul 2007
    Posts
    639
    Default
    Matho have a look at the grips on your lines.......
    the sides are not symmetrical....
    This being a boat hull and all..should the sides be the same..?
    I would suggest drawing one side only "about a centreline" then mirror..
    you could then join them with pedit if you like...
    If at first you don't succeed, then maybe failure is more your style.
  6. #6
    Using
    AutoCAD 2008
    Join Date
    Oct 2007
    Location
    Posts
    25
    Default
    Quote Originally Posted by PS_Port View Post
    I was trying to different things such as break, explode, trim etc in this particular case, hence the uneven poly. I'll have to build a bridge and keep on mirroring. Thanks
  7. #7
    Super Member chrisdarmanin's Avatar
    Using
    AutoCAD 2009
    Join Date
    Feb 2006
    Location
    Malta
    Posts
    524
    Default
    i managed to do it right... its the way you select it, not too far away from the fillet or not to near
    Quote by George (AWDC Malta President) about Land Rovers:
    "Trid ittiha xebgħa mazza ta' bla raġuni"
    Translation: You have to attack it with a mallet for no reason at all"
  8. #8
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    2,968
    Default
    Or perhaps draw a circle with the TTR option, and trim to suit
  9. #9
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,786
    Default
    Been my pet hate for years fillet two arcs ie 3 curves autocad draws an S bend.
    Our civil software recognises this problem as there are 4 soloutions and asks for an approx centre so you get the correct answer.
Similar Threads
  1. how to fillet radius for a box by command VBA
    By mud in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Feb 2008, 08:29 pm
  2. Create a fillet/radiused transition on a bolt shaft
    By ShawnPeter in forum AutoCAD General
    Last Post: 24th Jan 2008, 05:15 pm
  3. Fillet command on pline?
    By Kollargoll in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Oct 2007, 01:04 pm
  4. create a fillet in lisp
    By BEACHCOMBER in forum AutoCAD General
    Last Post: 29th Sep 2007, 10:52 am
  5. Fillet command.
    By humpieke in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jul 2007, 09:42 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
