the command is LAYTHW
Hello..
can u anyone tell me what is the shortcut commands to Unfreeze the Layers. (eg. LAYFRZ for freeze the layers)
Thanks & Regards
Life's constantly changing - keep up or get left behind
and it thaws EVERYTHING...just to clarify
(and yes, I just tried it...thank god for Undo)
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Remember tho' that this only thaws layers in the model... the VPLAYER command or Layer Manager has to be used to thaw layers in paperspace viewports![]()
You will also need to use the Layer Dropdown List or Layer Manager to individually thaw layers.Originally Posted by Tiger
