Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: 3D pipes
    Forum Newbie danieldalio's Avatar
    AutoCAD 2008
    Mar 2008
    Córdoba, Argentina
    6
    Question 3D pipes
    Good night,
    I am trying to draw some pipes in 3D.
    What I want to is to create a path, let's say from 0,0,0 going 10 feet up, then 15 feet to the left, then 8 feet forward, then 3 feet down and so on.
    I want smooth corners, not 90 degrees.
    It is my understanding that I can't make a 3D polyline with arcs on it.
    I'd like to make my piping by extruding a surface along a path.
    Is it any way to make my piping other than creating segments and elbows and joining everything?
    Thanks in advance.
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    What version of Autocad are you using? I would suggest using the sweep command or extrude along a path (for older versions).
    Edit: Simple way for the sweep command is build your path using extruded boxes then you can do it in one hit.
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    I played with it, all I came up with;
    -Draw 3dpolyline as you described
    -explode to 3dlines
    -use fillet command to create 3darcs at angles
    -draw circle for pipe section at end of each element, for use in extrusion
    (create ucs with "za" "ob" options for drawing circles)
    -extrude circle along each straight section and arc
    -"union" command to join solid pieces
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    You might like a free pipe program, ACAD add on.
    Try http://www.charlottepipe.com/Default...ge=AllDrawings for a free CD!
    I am always workin' with pipe, fittings, chemical storage tanks, find add-ons, freebies, a great asset for my work!
  5. #5
    Senior Member
    Architecture 2011
    Jan 2008
    100
    Default 3d Pipe Fittings AutoCAD
    To make your 3D Poly line have curves simply click on the Polyline then, in properties (under fit/smooth), select cubic. If you need the pipe run to have "tighter"/smaller radii then select quadratic (but bear in mind that quadratic uses a LOT more memory so in large drawings it is best to be avoided.
    If you have a choice between using sweep and extrude then I recommend going for the extrude option because the resulting pipe run will again be less memory intensive.
    The problem with the 3D polyline method is that the radii aren't exact. If you needed the run to represent an ANSI steel run then your path wouldn't match your fittings (this might be acceptable for you). You will also run into problems if you wanted to do a BOM/parts list (much simpler when using singular pipe fittings).
    If you truelly need to define pipe runs by their paths without having to manually insert the pipe fittings then you would need a program such as AutoCAD MEP.
    If you would be happy with individual pipe fittings then try one of these:
    [FONT='Arial','sans-serif']3D AutoCAD Pipework – http://www.HerculeDesign.com[/FONT][FONT='Arial','sans-serif'][/FONT]
    [FONT='Arial','sans-serif']Pipework & Structural Steel http://www.3DCADMax.com
    [/FONT]
  6. #6
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    Some of 3D-pipes programs. xpipe - for solid pipes, xtube - for solid pipes with hole.
    Code:
    (defun c:xpipe(/ ACTDOC ACTLAY ACTSP BASELINE
              BASESET CIRENT DICOUNT DIVDID
              EXCIR LAYST OBJTYPE OLDDIA
              OLDECHO STARTPT XORD YORD
              ZORD *ERROR*)
      (vl-load-com)
      (defun *error* (msg)
        (vla-put-Lock actLay laySt)
        (setvar "CMDECHO" oldEcho)
        (vla-EndUndoMark actDoc)
        ); end of *error*
      (if(not pipe:exDia)(setq pipe:exDia 40.0))
      (setq actDoc
        (vla-get-ActiveDocument
          (vlax-get-Acad-object))
       actLay(vla-get-ActiveLayer actDoc)
            oldDia pipe:exDia
            oldEcho(getvar "CMDECHO")
       ); end setq
      (vla-StartUndoMark actDoc)
      (setvar "CMDECHO" 0)
      (if(= 0(vla-get-ActiveSpace actDoc))
        (setq actSp(vla-get-PaperSpace actDoc))
        (setq actSp(vla-get-ModelSpace actDoc))
        ); end if
      (setq laySt(vla-get-Lock actLay))
      (vla-put-Lock actLay :vlax-false)
      (setq pipe:exDia
        (getreal
          (strcat
            "\nSpecify pipe diameter <"(rtos pipe:exDia)">: ")))
      (if(null pipe:exDia)(setq pipe:exDia oldDia))
      (initget "Yes No")
       (setq delFlag
              (getkword "\nDelete extrude path(s)? [Yes/No] <No>: "))
        (if(null delFlag)(setq delFlag "No"))
      (princ "\n<<< Select objects to extrude and press Enter >>>")
      (if
        (setq baseSet
          (ssget '((-4 . "<OR")(0 . "*LINE")(0 . "CIRCLE")
               (0 . "ARC")(0 . "ELLIPSE")(-4 . "OR>")
               (-4 . "<NOT")(-4 . "<OR")(0 . "SPLINE")
                    (0 . "MLINE")(-4 . "OR>")(-4 . "NOT>"))))
          (setq baseSet(vl-remove-if 'listp
                                  (mapcar
                'cadr
                (ssnamex baseSet))))
          (foreach pathEnt baseSet
          (setq baseLine
            (vlax-ename->vla-object pathEnt)
           objType(vla-get-ObjectName baseLine)
                startPt(vlax-curve-getStartPoint baseLine)
                3dPos
            (vlax-curve-getFirstDeriv baseLine
              (vlax-curve-getParamAtPoint baseLine startPt))
               diCount(strlen
                (itoa
             (apply 'max
              (mapcar 'abs
               (mapcar 'fix startPt)))))
           divDid "1"
           ); end setq
          (repeat diCount
       (setq divDid(strcat divDid "0"))
       ); end repeat
          (setq divDid(atoi divDid))
          (if(/= 0.0(car 3dPos))
       (setq XOrd(/(car 3dPos)divDid))
       (setq XOrd (car 3dPos))
       ); end if
          (if(/= 0.0(cadr 3dPos))
       (setq YOrd(/(cadr 3dPos)divDid))
       (setq YOrd (cadr 3dPos))
       ); end if
          (if(/= 0.0(nth 2 3dPos))
       (setq ZOrd(/(nth 2 3dPos)divDid))
       (setq ZOrd (nth 2 3dPos))
       ); end if
          (setq 3dPos(list XOrd YOrd ZOrd))
      (setq exCir
        (vla-addCircle actSp
          (vlax-3d-Point startPt)
          (/ pipe:exDia 2)))
      (vla-put-Normal exCir(vlax-3D-point 3dPos))
      (setq cirEnt(vlax-vla-object->ename exCir))
      (command "_.extrude" cirEnt "" "_p" pathEnt)
      (command "_.erase" cirEnt "")
     (if(= "Yes" delFlag)
        (vla-delete baseLine)
           ); end if
       ); end foreach
           ); end progn
          ); end if
        ); end  of c:xpipe
  7. #7
    AutoCAD 2008
    Mar 2008
    Córdoba, Argentina
    6
    Many thanks !!!!
    Sincerely.
    Daniel
  8. #8
    AutoCAD 2008
    Nov 2005
    1,427
    Excuse... XTUBE - this:
    Code:
    (defun c:xtube(/ 3DPOS ACTDOC ACTLAY ACTSP BASELINE
              BASESET DICOUNT DIVDID EXCIR EXENT
              EXTUBE INCIR INENT INTUBE LAYST
              OBJTYPE OLDECHO oldWidth oldHeight
              STARTPT XORD YORD ZORD DELFLAG *ERROR*)
      (vl-load-com)
        ); end of *error*
      (if(not tube:Width)(setq tube:Width 40.0))
      (if(not tube:Height)(setq tube:Height 37.0))
      (setq actDoc
            oldWidth tube:Width
       oldHeight tube:Height
       ); end setq
        ); end if
      (setq tube:Width
        (getreal
          (strcat
            "\nSpecify external diameter <"(rtos tube:Width)">: "))
           tube:Height
        (getreal
          (strcat
            "\nSpecify internal diameter <"(rtos tube:Height)">: "))
       ); end setq
      (if(null tube:Height)(setq tube:Height oldHeight))
      (if(null tube:Width)(setq tube:Width oldWidth))
      (if(< tube:Height tube:Width)
            (initget "Yes No")
       (setq delFlag
      (if
        (setq baseSet
                                  (mapcar
                'cadr
          (setq baseLine
                3dPos
               diCount(strlen
                (itoa
             (apply 'max
              (mapcar 'abs
           divDid "1"
           ); end setq
    	(repeat diCount
       ); end repeat
       ); end if
       ); end if
       ); end if
      (setq exCir
          (/ tube:Width 2))
       inCir
          (/ tube:Height 2))
       ); end setq
      (vla-put-Normal inCir(vlax-3D-point 3dPos))
      (setq exEnt(vlax-vla-object->ename exCir)
       inEnt(vlax-vla-object->ename inCir)
       ) ; end setq
      (command "_.extrude" exEnt "" "_p" pathEnt)
      (setq exTube(entlast))
      (command "_.extrude" inEnt "" "_p" pathEnt)
      (setq inTube(entlast))
      (command "_subtract" exTube "" inTube "")
      (command "_.erase" exEnt "")
      (command "_.erase" inEnt "")
           ); end if
       ); end foreach
           ); end progn
          ); end if
         ); end progn
        (princ "\nInternal diameter more or equal external diameter! ")
        ); end if
        ); end  of c:xtube
  9. #9
    Senior Member khama's Avatar
    khama's Computer Details
    Windows 7 Ultimate
    INTEL CUSTOM i5
    GIGABYTE HD55-UD3A i7
    CORE I5 3.2GHz
    6GB CORSAIR DDR-3
    NVIDIA Quadro FX 3800 Graphics adapter - 1 GB - GDDR3 SDRAM
    SAMSUNG 660GB SATA
    SAMSUNG 1TB
    2 x DELL PRECISION 30"
    Mechanical
    khama's Discipline Details
    Project Leader, Engineering, Oil and Gas and Materials Handling
    Mechanical
    Mechanical is my strongest Discipline. Civil and Structural are all strengths for me too.
    AutoCAD 2011
    Mar 2008
    Australia
    206
    Quote Originally Posted by danieldalio View Post
    Good night,
    Thanks in advance.
    Sure you can...
    type: pline (enter)
    a (enter) this will take you into the arc command for polylines
    to go back to a straight line type: L
    As far as making piping using the extrude command or sweep command. Make a chosen path, fillet the corners using this formula
    1.525 x Diameter of the pipe. It is really quite simple. I am sure you will work it out. Aternatively, you can use ready made 3d blocks from programs like Inventor or Mech-Q. That is even easier again..
    Khama
    Bachelor of Science Mechanical Engineering
    Diploma Civil & Structural Engineering
    Diploma Engineering NDT
  10. #10
    Forum Newbie
    AndrewCollins94's Computer Details
    Dell Precision T3400
    Mechanical
    AndrewCollins94's Discipline Details
    Apprentice
    Mechanical
    I work for a small independent company who deals with Fire Sprinkler Systems which vary from Care Homes to Multi-million pound companies across the United Kingdom and Europe.
    AutoCAD 2013
    May 2012
    Saddleworth
    1
    How do I keep this in AutoCAD XPIPE and XTUBE as they are ideal for my job?
  1. User guides for Civil 3D: Roads and pipes
    By rusty in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2007, 03:28 pm
  2. Civil Design 3.0 Using the Pipes puldown
    By tazzvon in forum AutoCAD General
    Last Post: 1st Dec 2006, 08:24 pm
  3. Using spline with line to draw pipes in 2D
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2006, 06:57 pm
