Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    Land Desktop 2005
    Jan 2008
    7
    Default DVIEW twist or UCS
    I am trying to figure out what would be the best/quickest/most simple way to rotate a drawing.
    I know dview twist works well. That is what im use to but there has to be an easier way to use it than what i have been doing.
    When i use dview twist it is kind of a guessing game to how it will be rotated. I draw a box, align it with what i want to be horizontal in paper space, draw a line to show north so i can make sure my view will be north up or to the right then i rotate it.
    Other people at work use the UCS FOLLOW then create names for the views. My problem with that is the coordinates gets screwed up.
    What is the Best way to twist a drawing for simple dimensioning and labeling, but still easy inserts from 0,0... like how can i get the quick leader text to still come in horizontal with paper space with the view twisted.
    Thanks for any help / advice.
    Much appreciated
    Super Member
    Land Desktop 2006
    Nov 2007
    Chandler, Az
    548
    Are you creating a viewport than twisting your drawing within that viewport? if you do that you should be able to just dimension in paperspace and everything will read right. Unless Im misunderstanding the problem, it is all a preference thing when it comes to how to do certain things. I have a twist lisp routine that allows to just pick two points tha you want to be horizontal. I can post it tomorrow if youd like...
    Forum Deity
    lpseifert's Computer Details
    A bit faster than an abacus
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,258
    Try putting this in your acaddoc.lsp file
    Code:
    (defun c:ue ()(command "ucs" "e"))
    (defun c:uw ()(command "ucs" "w"))
    (defun c:uv ()(command "ucs" "v"))
    (defun c:up ()(command "ucs" "p"))
    (defun c:uo ()
        (setq pt1 (getpoint "Pick reference point: ")
                el (RTOS(* -1.0(getreal "Enter elevation: ")))
                CO (STRCAT "0," el)
        (command "UCS" "o" pt1)
        (command "UCS" "o" CO))
    UE will align the UCS to an entity
    UW will restore the UCS to World
    UV will align the UCS to view (good for annotation)
    UP will restore the UCS to the previous
    UO will set the UCS to an elevation (Y coordinate)... good for profiles
    Forum Newbie
    Land Desktop 2005
    Jan 2008
    7
    Default Thank You
    Quote Originally Posted by smorales02 View Post
    we dont dimension in paperspace... and i think that is pretty lame. I just dont have the athority to make that change.
    lpseifert: Thanks for the Lisps!!
    i want to use UCS and do everything in paperspace. we'll see.
  5. #5
    Super Member
    Land Desktop 2006
    Nov 2007
    Chandler, Az
    548
    Ive always dimensioned in paperspace till I got to this new company which likes to show everything in modelspace. So I would come across the same problem you are, my work around was to do all my work in paperspace (dimensions and such) than just do a CHSPACE for all of them...works out good for me, maybe something you should try.
  6. #6
    Forum Newbie
    Land Desktop 2005
    Jan 2008
    7
    yeah same here... I love change space!
    Thanks again.
  7. #7
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    Have you tried using the MVSETUP to rotate your drawing? That's how we rotate our sites.
  8. #8
    SLW210's Computer Details
    Windows XP Pro
    HP Compaq dc 7600 Convertable
    ACPI Multiprocessor
    Intel Pentium D 3.4 GHz
    2 GB RAM
    NVIDIA Quadro NVS 285
    Stotage:
    250 GB
    Sony Multiscan E540 & Viewsonic P815
    AutoCAD 2008
    May 2007
    Memphis, TN USA
    3,445
    Quote Originally Posted by BOB'27T View Post
    It is MVSETUP>Align>Rotate View. I use that also.
    Be careful what you wish for, it may come true.
  9. #9
    Forum Newbie
    Land Desktop 2005
    Jan 2008
    7
    Yes i run into some of the same issues as dview twist. Becaues for whatever reason we still dimension & label in model space.
  10. #10
    Super Member rustysilo's Avatar
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,451
    I do it like you, draw a line and get the angular dim to input in dview > twist. Then I set my viewport at that twist value and change my snapang for the twisted view to do my notes and such.
    This works fine for me, however it seems like there was a way to automate the dview > twist so that you could simply select an object or something to align the view with.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr | myspace
    | work | business | creed
    rustysilo's tips & tutorials
  1. dview twist
    By ktlandscapearchitect in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2007, 11:39 pm
  2. Other Than Dview
    By chance in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2006, 07:01 pm
  3. UCS or Dview?
    By Tconn in forum AutoCAD Drawing Management & Output
    Last Post: 1st Dec 2006, 02:06 pm
  4. rendering in dview
    By jess in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd May 2006, 07:03 pm
  5. Dview command
    By alitasi in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2004, 11:05 pm
