Results 1 to 3 of 3
    Forum Newbie mt1083's Avatar
    AutoCAD 2008
    Mar 2008
    4
    Default Custom arrow / leader help
    Hey guys, i have been trying to figure out how to use a custom arrow here at work so that we can start using leaders. But there are two things that I can't figure out...
    1. i'm not exactly sure what size to make the arrow and what type of block to make in order to make it scale up and down since i want it annotative.
    2. There is a gap between the arrow and the leader line and i can't figure out why.
    the leader that is drawn there is the one that i am having the problem with and the arrow that is just floating off in space is the size that I want the arrow to show up at in 1/4"=1'-0" scale.
    Can anyone help me? I am using ACAD 2008...
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Acad assumes that custom arrowheads are 1 unit long (in your case 1"), so the start of the leader line starts 1 unit from the base pont. In this case you'd want to move the base point 1 unit to the right on your arrow block.
    AutoCAD 2008
    Mar 2008
    4
    ahhh...that takes care of #2. You are awesome! and now for some reason the scaling is working fine now. So all my questions are answered. Thanks!
  1. leader arrow heads and shoulder
    By wastewater in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Feb 2008, 04:09 pm
  2. Help with custom leader
    By croz in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Oct 2007, 07:12 pm
  3. Leader Arrow Size
    By DODGE in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2006, 06:40 pm
  4. re Closed Blank Leader Arrow ;
    By davidv in forum AutoCAD Drawing Management & Output
    Last Post: 19th Aug 2004, 09:19 am
  5. Leader arrow head is very small
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 17th May 2004, 05:36 pm
