Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2007
    Feb 2007
    7
    Default Automatic Extraction of Elevation Properties of Points on a Line
    Please can anyone assist in locating a lisp program for Automatic Extraction of Elevation Properties of Points on a Line. I need this because, I need to use the elevation of points at specific intervals on a line to draw the longitudinal profile of the line.
    Thank you.
    Skipo
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Using some math.
    If a line has the ends at elevations Z1 and Z2 and you wish to calculate say 15 intermediate points:
    DZ=(Z2-Z1)/15
    Now the 3rd intermediate point will have the elevation Z1+3*DZ
    The 9th point will be at Z1+9*DZ
    and so on
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD 2006
    Nov 2002
    3,540
    I just wrote a short Lisp for you:
    Code:
    ;Divides a line in equal segments and write the WCS elevation for each division
    ; Fuccaro Miklos   March 2008
    (defun c:elevations( / l ll p1 p2 p n i cont)
      (defun blmaker()
        (if (not (tblsearch "BLOCK" "POINTMARKER"))
     (entmake '((0 . "BLOCK")(2 . "POINTMARKER")(70 . 2)(10 0 0 0)))
     (entmake '((0 . "POINT")(10 0 0 0)))
     (entmake '((0 . "ATTDEF")(10 0 0)(1 . "f")(2 . "fuccaro")(3 . "miklos")
             (40 . 3.5)(41 . 1)(70 . 4)(72 . 2)))
     (entmake '((0 . "ENDBLK")))
      (defun blins (poz)
        (entmake (list '(0 . "INSERT") '(66 . 1) '(2 . "POINTMARKER") (cons 10 poz)))
        (entmake (list (cons 0 "ATTRIB")
         (cons 10 poz)
         (cons 11 poz)
         (cons 70 8)
         (cons 72 2)
         (cons 40 3.5)
         (cons 1 (rtos (caddr poz)))
         (cons 2 "fuccaro")
        (entmake '((0 . "SEQEND")))
      (setq cont t)
      (while cont
        (setq l (entsel "line?"))
        (if l (setq ll (entget (car l))))
        (setq cont (not (eq "LINE" (cdr (assoc 0 ll)))))
      (setq p1 (cdr (assoc 10 ll)) p2 (cdr (assoc 11 ll)))
      (setq n (getint "divisions?"))
      (blmaker)
      (setq i 0)
      (repeat (1+ n)
        (setq p (list
           (+ (car p1) (/ (* i (- (car p2) (car p1))) n))
           (+ (cadr p1) (/ (* i (- (cadr p2) (cadr p1)))n))
           (+ (caddr p1) (/ (* i (- (caddr p2) (caddr p1)))n))
        (blins p)
        (setq i (1+ i))
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Civil 3D will do this for you on a feature line. Otherwise use fuccaro's script.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  1. Automatic Line And Curve Labeling
    By ff7734 in forum AutoCAD Drawing Management & Output
    Last Post: 18th Oct 2009, 06:40 pm
  2. Line data extraction in AutoCAD 2005
    By rev.beernan in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2008, 04:20 pm
  3. Attribute Extraction, fully automatic
    By Kollargoll in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Sep 2007, 10:42 am
  4. add vertex z or elevation to points
    By gvlisnas in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2007, 11:14 pm
  5. AUTOMATIC BREAK/TRIM A LINE WHEN INSERTING A SYMBOL
    By Frederik in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2005, 08:52 am
