Results 1 to 2 of 2
    Full Member
    Architecture 2009
    Jan 2005
    Chichester England
    65
    Default Non visabile tags
    Autocad Architecture 2008
    Base drawing has various out of the box door and wall tags. The drawing is then xrefed into the final sheet. The problem is that the tags are not visible in the paperspace viewport, (they are visible in model space). All layers are turned on within the paper space viewport. Is there a setting of some description that controls the visibility of the tags?
    "If I have seen further it is by standing on the shoulders of Giants." --Isaac Newton
    ADT 2009
    Full Member
    Architecture 2009
    Jan 2005
    Chichester England
    65
    The solution is here. Ensure that the annotation scale of the tags the same as the scale of the viewport.
    Simple when you know how!
    http://discussion.autodesk.com/threa...sageID=5740881
    ADT 2009
  1. Northing and Easting tags?
    By BigMikeLV in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2008, 04:45 pm
  2. Wall Tags
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 16th Oct 2007, 07:37 am
  3. Wall Tags in 2008
    By Cad Sponge in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2007, 04:14 pm
  4. ADT 3.3 Custom Schedule Tags
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2006, 05:27 pm
  5. Help with Tags...or?
    By Cutter in forum AutoCAD General
    Last Post: 11th Apr 2006, 03:41 pm
