stretch an image
dugg
Seems like I remember one time being able to stretch an image in the x direction and the y direction not being affected by it or vice versa. When I do it now it seems to scale it. So how does one make an image a different scale in one direction than the other?
I got access to cadoverlay and raster design if that makes any difference.
Insert your image file into an empty drawing and then insert that drawing as a block into your current drawing. You can then adjust the X and Y values independantly in the Properties palette.
i dont think u can stretch an image in autocad,
if ur images r xrefs then i would modify the attched image file using an external app like paint.
if there ole objects just right click on the image n select open n depending on the image it will open in the original app that it was created with then modify it from there
The image will still scale from memory. if u change the length the width will update automatically
No, I double checked before I posted. Insert the image into a drawing and then insert that drawing as a block. You can then adjust the X and Y values independantly in the Properties palette. I tried to post an screenshot, but I'm having technical difficulties at the moment.
sorry your right it does, i just gave it ago, i missed the important part about inserting it as a block the first time n jumped the gun a bit
  • 7 years later...
if its an OLE object, click on it and on the Properties Panel > Lock aspect - select no.
you can now adjust or stretch in your case, the Height and Width of the image
cad64, can you make a video on how you did it.. thanks in advance :)
Wow! This is an old thread.
It's pretty simple to do. If you know how to insert an image, create a block and open your Properties palette, you should be able to do this with no trouble at all.
