Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: Delete command
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    Question Delete command
    Hi
    Does anyone know how to erase/delete everything inside a given area on a drawing.
    I need to erase a lot of lines etc in a given area without selecting everyline individually. I would like to outline the area with a poly line and with 1 command delete everything insize or outside that closed polyline.
    Any suggestions.
    Thanks
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    Here is a lisp for it. It is called CHOP, you draw a window or pline around all the items that need to be erased.
    Senior Member CADgirl's Avatar
    Structural
    CADgirl's Discipline Details
    CAD Drafter, Seismic Retrofitting
    Structural
    AutoCAD 2018
    Nov 2006
    Orange County, CA
    278
    When you select the erase command you can use the pickbox to select a large area- just hold the mouse button down and outline the area you would like to erase. If you move the pickbox to the left any object the boundaries are touching will be erased. If you move it to the right only objects where the entire object is in the selected area will get erased.
    I don't know if that answers your question, you probably already knew about the selection methods.
    I don't know how to do it using a polyline.
    "All I've ever wanted was an honest week's pay for an honest day's work."
    -Steve Martin
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Type E (Erase) on the command line, when prompted to select objects, type W (Window), Shift+Right-Click and select a snap, if you want to snap to the box, Hit Enter to Erase.
    Or use that lisp. Thanks, I will check that out.
  5. #5
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    Unhappy
    Sorry
    The above commands/lisp dont do what I require or at least I dont seem to be able to get them to do what i require.
    I want to delete everything within a polyline. This includes breaking lines if the polyline intersects that line, I dont want anything deleted beyond that line.
    Thanks
  6. #6
    Full Member
    AutoCAD 2008
    Mar 2008
    56
    If you have just a few lines/objects you wish to keep as oppose to many you wish to delete then just move the objects/lines you want to save to another layer (0 layer comes to mind) & goto Edit>Select All then hit your delete key.
  7. #7
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    Sorry I dont think you understand.
    This is an example,
    I have a landscape as built drawing of a garden. The boundary is set and not going to change. I would like to outline the boundary and delete everything inside that boundary. I could select all the items one by one and create a new layer then delete them but that seems very long winded.
    I am sure there must be a lisp to create a boundary and deleted everything within that boundary.
    Thanks for the feedback.
  8. #8
    Structural
    Structural
    AutoCAD 2018
    Nov 2006
    Orange County, CA
    278
    Can you post a screenshot? Maybe that will help us understand what you want.
    -Steve Martin
  9. #9
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    I have attached a simple (not real) example.
  10. #10
    Structural
    Structural
    AutoCAD 2018
    Nov 2006
    Orange County, CA
    278
    If you draw a polyline, like you have in the example, can you use trim? I can't tell where the lines go and what's connected to what, but I would think you could use trim and then erase whatever is left over.
    -Steve Martin
  1. Delete key
    By steve @ mp in forum AutoCAD Drawing Management & Output
    Last Post: 5th Feb 2009, 11:27 pm
  2. Help! Delete problems
    By Chuck W in forum AutoCAD Beginners' Area
    Last Post: 4th Jul 2007, 11:29 pm
  3. delete outside a template
    By BDCEng in forum AutoCAD General
    Last Post: 14th Nov 2006, 01:05 am
  4. how can I delete a block with vba, help me!
    By jeans in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jul 2005, 07:16 pm
  5. Delete Layer(s)
    By CADTutor in forum Application Archive
    Last Post: 3rd Dec 2004, 08:12 pm
