Results 1 to 4 of 4
    Forum Newbie
    not applicable
    Mar 2008
    4
    Default Another ProgeCad Question - dimensions?
    Per SLW210's recommendation, I've downloaded progeCAD 2008.
    One simple question I have is this:
    How do I determine the dimensions of my drafts? I don't understand how to interpret the info on the left hand side. I'm trying to make patterns that will print out about the size of a human foot. So I'm trying to measure everything in inches or cm.
    Thanks
    Last edited by Cad64; 21st Mar 2008 at 01:18 am. Reason: Modified title to something a bit more appropriate
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Since this is a ProgeCad question, I have moved your post to the Design Software section. I don't know how many members actually use this program though. You might want to see if you can find a ProgeCad forum.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    If this can wait till Monday I will see if I can help you more. Not sure what you are referring to. Click at the top where it says dimensions, select the type of dimension and click on where you want to dimension. For all others reading this, Progecad is pretty much the same as AutoCAd, so most advice will work for the 2.
    Leatherguy, if you will go through this Dimension Tutorial it may be all you need. All of the acad tutorials should help you in progeCAD.
    Forum Newbie
    not applicable
    Mar 2008
    4
    Thanks,
    Well basically I'm just trying to figure out how long a line is. If I draw a square or rectangle, for example. How do I tell that I'm drafting a 5" line and not a 6" line?
  1. ProgeCAD LT - anybody have a link for this?
    By f700es in forum Catch All
    Last Post: 19th Oct 2008, 12:15 am
  2. Dimensions Question
    By daveyboyd in forum AutoCAD Drawing Management & Output
    Last Post: 25th Dec 2007, 05:59 pm
  3. ProgeCad
    By Wozza in forum AutoCAD Drawing Management & Output
    Last Post: 21st Nov 2007, 03:50 pm
  4. ProgeCAD LT 2006
    By Vince0115 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Feb 2006, 07:48 am
  5. Question regarding Dimensions
    By Xaquin in forum AutoCAD General
    Last Post: 24th Aug 2005, 02:31 pm
